Mixalis Member 38 Member For: 10y 10m 9d Posted 28/07/20 12:53 AM Share Posted 28/07/20 12:53 AM Hi all, Have done a quick search - not sure if anyone has asked this qtn before. Has anyone figured out a way to bring the accelerator pedal a little higher than the factory position? Reason I ask is because I have found that the accelerator is a little low relative to the brake pedal - making it a little hard to blip the throttle while under braking (I plan to track the car a little bit in the future). From what I've seen, the way the pedal mounts to the pedal box is a little peculiar. I have a mill and can also fabricate, so I don't mind giving it a crack eventually, just wanted to see if anyone else has an existing solution before I have a go Cheers! Michael Link to comment Share on other sites More sharing options...
joncitizen Member 91 Member For: 12y 6m 26d Posted 28/07/20 12:20 PM Share Posted 28/07/20 12:20 PM You could put an adjustable pedal box in - assuming auto... Your steering column already has the wiring, the switch goes into the recess/blank out below the barrel... Now I have seen some that just bring the brake pedal up/down and some that bring both up and down together... Might be worth looking into... 1 Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 1d Gender: Male Location: Perth Posted 28/07/20 01:16 PM Share Posted 28/07/20 01:16 PM Auto or manual. Link to comment Share on other sites More sharing options...
Mixalis Member 38 Member For: 10y 10m 9d Posted 28/07/20 10:34 PM Author Share Posted 28/07/20 10:34 PM Manual 12 hours ago, joncitizen said: You could put an adjustable pedal box in - assuming auto... Your steering column already has the wiring, the switch goes into the recess/blank out below the barrel... Now I have seen some that just bring the brake pedal up/down and some that bring both up and down together... Might be worth looking into... Thanks for the reply mate, mine is a manual. Did some reading and it seems it’s just the autos that seem to have the adjustable pedals... Is there a specific model that had the adjustable accelerator? Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,013 Member For: 8y 11m 6d Gender: Male Location: Canberra ACT Posted 29/07/20 01:46 AM Share Posted 29/07/20 01:46 AM Pretty sure the whole pedal box moves in and out - they don't adjust independently of each other. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,044 Member For: 9y 1m 28d Gender: Male Location: South Australia Posted 29/07/20 01:49 AM Share Posted 29/07/20 01:49 AM My territory has it. I just checked and both pedals move together. They don't move very far though. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 1d Gender: Male Location: Perth Posted 30/07/20 09:45 AM Share Posted 30/07/20 09:45 AM On 29/07/2020 at 6:34 AM, Mixalis said: Manual Thanks for the reply mate, mine is a manual. Did some reading and it seems it’s just the autos that seem to have the adjustable pedals... Is there a specific model that had the adjustable accelerator? Accel needs to be lower for heel toe as you press the brake pedal down.. When on the track I just left foot brake. Then you can give it a dab when the tyres start to spin. Link to comment Share on other sites More sharing options...
Mixalis Member 38 Member For: 10y 10m 9d Posted 30/07/20 10:55 AM Author Share Posted 30/07/20 10:55 AM Definitely need the accelerator pedal to come up, even under full brakes I can only just get to the throttle. Most aftermarket kits for other cars with similar pedal height differences are spacers that being the throttle pedal up (Focus for example). If the DBW pedal to throttle body relationship was adjustable I might have been able to make it more sensitive. Anyway I’ll see if I can rig up something if it’s possible at all, thanks all! 1 Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 1d Gender: Male Location: Perth Posted 30/07/20 11:20 AM Share Posted 30/07/20 11:20 AM (edited) Watch, spacing it up. As when you mash it you will have to much travel and brake it. Get it brake it..... I can heed toe in my manual F6 , But just learn to left foot brake. Edited 30/07/20 11:25 AM by arronm Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 8m 7d Posted 30/07/20 11:27 AM Share Posted 30/07/20 11:27 AM I agree, I can't heal and toe as the throttle is too low. Not with any consistency anyway. Could easily make an adapter plate to reposition the throttle. 1 Link to comment Share on other sites More sharing options...
