Turbo0000 New Member 15 Member For: 3y 9m 13d Posted 06/07/20 11:34 PM Share Posted 06/07/20 11:34 PM (edited) Apologies for the noob question. I have a ba xr6t and a boost gauge to install, yet I have no bov. I was wondering where to install the t piece as usually it would be connected through the vacuum line from the bov if I'm correct. But since I have no bov, I'm lost Edited 06/07/20 11:35 PM by Turbo0000 Noob* Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,019 Member For: 8y 11m 28d Gender: Male Location: Canberra ACT Posted 07/07/20 12:00 AM Share Posted 07/07/20 12:00 AM There is most likely a vac line that was blocked off when the factory BOV was removed. If you can find that you can just use that. 2 Link to comment Share on other sites More sharing options...
Turbo0000 New Member 15 Member For: 3y 9m 13d Posted 07/07/20 03:40 AM Author Share Posted 07/07/20 03:40 AM The only one I can find is the one that goes into the bov, but it seems way too big in diameter to be hooked up to the small brass piece on the back of the boost gauge. Am I missing something? Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,019 Member For: 8y 11m 28d Gender: Male Location: Canberra ACT Posted 07/07/20 03:53 AM Share Posted 07/07/20 03:53 AM Sometimes boost gauges have small fittings for plastic tube and then an adaptor to the vac line so that you don't have to run vac line all the way to the dash. Post a pic of the back of the gauge and the vac line you found. Link to comment Share on other sites More sharing options...
Turbo0000 New Member 15 Member For: 3y 9m 13d Posted 08/07/20 06:03 AM Author Share Posted 08/07/20 06:03 AM Sorry for the long wait, car was getting fixed Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,019 Member For: 8y 11m 28d Gender: Male Location: Canberra ACT Posted 08/07/20 06:20 AM Share Posted 08/07/20 06:20 AM It looks like your boost gauge line is smaller diameter than the vac lines, but has that T piece.So connect that line to the gauge and into the middle of the T. Then just cut a vac line under the bonnet and connect those to each end of the T. I'll grab a photo later if the sort of thing you are looking for.That BOV you have taken a photo of is the actual air path for the BOV, not the vacuum line that controls operation of the valve. There will be a much smaller line floating around somewhere that been blocked off as well. You see the size you are looking for when I grab a photo. 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,117 Member For: 9y 2m 21d Gender: Male Location: South Australia Posted 08/07/20 06:26 AM Share Posted 08/07/20 06:26 AM Don't T into the fuel reg line though, they prefer to have their own uninterrupted manifold supply. Wouldn't be the end of the world if you did, but don't. Link to comment Share on other sites More sharing options...
Turbo0000 New Member 15 Member For: 3y 9m 13d Posted 08/07/20 06:41 AM Author Share Posted 08/07/20 06:41 AM I'll wait for that photo before I go messing around. Cheers mate I found this, this is definitely blocked Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,019 Member For: 8y 11m 28d Gender: Male Location: Canberra ACT Posted 08/07/20 07:21 AM Share Posted 08/07/20 07:21 AM You could put a hose on there and connect to your gauge. You'd have to still reduce it down to the size of that new line though, using the T.So you could plumb the gauge to the t with the supplied line. Then connect some vac line from the spot where the bolt currently is to the T. Then a bit more line off the T that you then block with a bolt. For reference, this is what a BOV set up looks like with a vac line to control the valve. Link to comment Share on other sites More sharing options...
Turbo0000 New Member 15 Member For: 3y 9m 13d Posted 08/07/20 08:15 AM Author Share Posted 08/07/20 08:15 AM Cheers mate for the help, I'll try it out tomorrow and report back. 1 Link to comment Share on other sites More sharing options...
