Bionic Beast Donating Members 29 Member For: 4y 5m Gender: Male Location: rAdelaide Posted 22/06/20 03:38 AM Share Posted 22/06/20 03:38 AM Hey everyone. So I was trying to remove the stock shift knob to replace the boot to no avail. However I did notice some movement but it wasn't from the knob. I've seemed to of broken the silicon or glue holding the smaller shift shaft into the thicker one (sorry I don't know the proper names). Now the two shafts rotate freely with little effort about not 360 but a fair good distance. Have I f*cked it and I need to buy a new stick or is there some way to fix it? Cheers Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 22/06/20 03:40 AM Share Posted 22/06/20 03:40 AM sounds like you've ruined the threads on the stick if it's spinning around and you've broken the glue... best off getting a replacement stick now. Link to comment Share on other sites More sharing options...
Bionic Beast Donating Members 29 Member For: 4y 5m Gender: Male Location: rAdelaide Posted 22/06/20 04:38 AM Author Share Posted 22/06/20 04:38 AM Its not the knob that's spinning that's still stuck on tight. Its the two piece shaft... Ive had a peek and there doesn't seem to be any threads (or ruined ones) Just a smooth shaft glues into a larger one. But if you still think that's the case then looks like I'm off to the wreckers or fraud Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 22/06/20 04:47 AM Share Posted 22/06/20 04:47 AM hmm... I can't remember there being two pieces in the shaft... just a metal shaft with threads with glue on it then the knob screwed onto that... Link to comment Share on other sites More sharing options...
Bionic Beast Donating Members 29 Member For: 4y 5m Gender: Male Location: rAdelaide Posted 22/06/20 05:07 AM Author Share Posted 22/06/20 05:07 AM Here is a video of the issue I'm having if it is any help.... Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 22/06/20 05:21 AM Share Posted 22/06/20 05:21 AM hmm, mine doesn't look anything like that green bit... looks aftermarket to me, but my memory might be faulty... Link to comment Share on other sites More sharing options...
danielknox281 New Member 17 Member For: 6y 10m 11d Posted 10/10/20 09:23 PM Share Posted 10/10/20 09:23 PM Any tips for how to remove the manual gear knob?? Mines a ba Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 10/10/20 10:52 PM Share Posted 10/10/20 10:52 PM you want the knob itself removed or just the shaft with the knob on it? Link to comment Share on other sites More sharing options...
joncitizen Member 91 Member For: 12y 7m 22d Posted 11/10/20 02:31 AM Share Posted 11/10/20 02:31 AM On 22/06/2020 at 3:21 PM, k31th said: hmm, mine doesn't look anything like that green bit... looks aftermarket to me, but my memory might be faulty... FYI that green bit is factory. 5 hours ago, danielknox281 said: Any tips for how to remove the manual gear knob?? Mines a ba Put it in a vice with rags and undo it. Be prepared for it to get damaged. You could also try with a oil filter strap tool, but I had no luck with it. Link to comment Share on other sites More sharing options...
danielknox281 New Member 17 Member For: 6y 10m 11d Posted 19/10/20 06:59 AM Share Posted 19/10/20 06:59 AM On 11/10/2020 at 9:52 AM, k31th said: you want the knob itself removed or just the shaft with the knob on it? Hey mate hopefully you get this, I was hoping to put a different knob on it, if I remove just the knob I should be able to just screw the new one on? Link to comment Share on other sites More sharing options...
