burkey05 Member 76 Member For: 10y 6d Gender: Male Location: Melbourne Posted 25/10/20 10:07 PM Share Posted 25/10/20 10:07 PM Hi Romulus, Just a question on the Terry front diffs you have. I'm after some measurements from the diff itself, but only if you've disassembled either of them. I was after measurements in between the side gears, and measurements between the pinion gears. Again only if you've got them apart. Trying to find any info on these diffs is near on impossible. Link to comment Share on other sites More sharing options...
Romulus Donating Members 1,279 Member For: 19y 3m 19d Location: Perth Posted 31/10/20 04:59 AM Author Share Posted 31/10/20 04:59 AM I haven't pulled apart the front diff so I can't help you. Not sure if the SZ front diff is different to the SY/SY2 front diff. I know the mounting position is. 1 Link to comment Share on other sites More sharing options...
Romulus Donating Members 1,279 Member For: 19y 3m 19d Location: Perth Posted 31/10/20 05:13 AM Author Share Posted 31/10/20 05:13 AM (edited) Re bush rime. Replacing all the factory bushes with Superpro. Given the cars only done 75000kms some of the original bushes are in bad condition, namely the front inner control arm and the radius arms. Ordered replacement radius arms rather than replacing the bushes alone. I ordered a 3.07 CW&P to replace the factory 3.23 gears as they were whining more than the bed wetters afraid of the government opening the borders. Alas, the 3.07 gears didn't work as they were not for the M86 diff as advertised. They'll be going back for a refund. Have to replace the right driveshaft as the outer shaft is leaking, spraying grease all over the shock absorber boot. I should feel some improvement to handling and hopefully the intermittent shuddering during braking will go away with the new bushes. Edited 31/10/20 05:18 AM by Romulus 3 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,300 Member For: 16y 13d Gender: Male Location: Melbourne Posted 31/10/20 06:18 AM Share Posted 31/10/20 06:18 AM should be a good upgrade 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 25d Gender: Male Location: South Australia Posted 31/10/20 06:46 AM Share Posted 31/10/20 06:46 AM 1 hour ago, Romulus said: outer shaft is leaking That happens with old age 1 Link to comment Share on other sites More sharing options...
Romulus Donating Members 1,279 Member For: 19y 3m 19d Location: Perth Posted 08/11/20 05:16 AM Author Share Posted 08/11/20 05:16 AM On 31/10/2020 at 2:18 PM, k31th said: should be a good upgrade It is. Bush upgrade has made a big improvement to handling. Car feels much sharper, heaps better on centre feel and the pulsating under braking is gone. The radius arm bushes and inner lower control arm bushes were shot. Diff whine has also gone with the install of the new 3.23 gears. Replaced the right driveshaft at the same time as the outer CV boot was leaking grease. 3 Link to comment Share on other sites More sharing options...
Romulus Donating Members 1,279 Member For: 19y 3m 19d Location: Perth Posted 05/12/20 04:45 AM Author Share Posted 05/12/20 04:45 AM New front seats arrived from Proseat Interiors. They're absolutely fantastic, provide excellent bolstering and support. Great upgrade, definitely worth the outlay. The tan leather interior I had is up for sale. 3 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,300 Member For: 16y 13d Gender: Male Location: Melbourne Posted 05/12/20 04:55 AM Share Posted 05/12/20 04:55 AM noice, looks like they modelled them off the GT-P seats Link to comment Share on other sites More sharing options...
Romulus Donating Members 1,279 Member For: 19y 3m 19d Location: Perth Posted 05/12/20 05:38 AM Author Share Posted 05/12/20 05:38 AM Yep, GTP seats. Had them in my BF2 Super Pursuit and loved them. Link to comment Share on other sites More sharing options...
Romulus Donating Members 1,279 Member For: 19y 3m 19d Location: Perth Posted 26/12/20 12:29 PM Author Share Posted 26/12/20 12:29 PM Notice a bit of driveline shunt over the last week or so. Got the car on the hoist and there's 15mm of freeplay in the pinion. Looks like the diff is coming out beginning of the new year for some warranty work. May as well change the centre bearing and uni at the same time as part of preventative maintenance. Link to comment Share on other sites More sharing options...
