EgoXR6Turbo Member 60 Member For: 6y 1m 11d Posted 16/06/20 12:36 PM Share Posted 16/06/20 12:36 PM I know this has probably been covered in some capacity 1000 times but I can’t quite get the information I’m after. I have a Fg manual xr6 turbo basically stock. It has the hybrid polyelast diff bushes in it. All the rear end was also changed at the same time every bush with super pro. It also has king springs and bilsteins. now don’t get me wrong the car drives mint but what I can’t get my head around is the thud when changing gears hard. You can get around this by being a bit more gentle between the shifts and loading up the tail shaft a little bit with the throttle but if your out and out changing gears hard I.e racing it will thud on changes. the information I have found is basically no matter what diff bush set up you have this is just how these cars are? Is this true. Does anyone know what is actually causing the thud? Driving around town and just cruising it’s sweet didn’t do it at all and if you get the shift just write it won’t do it but it’s pretty sh*t to be honest when you want to drive your car hard. I spoke to the shop they installed these and he said the bushes are all sweet and there was enough clearance on the out riggers from the way they pressed in the side bushes so I’m at a loss. I have been looking at getting the ims diff hat upgrade no issue spending the money if it fixes it but if it doesn’t I won’t bother. I can’t find any specific information from anyone who has a manual with either the ims diff hat or diff bush set up where basically they can drive it hard gear to hear and get no thud. Any feedback from ppl with the diff bushes I have or a set up that eliminates this would be awesome. cheers Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 14d Gender: Male Location: Melbourne Posted 16/06/20 01:01 PM Share Posted 16/06/20 01:01 PM yes, the diff hat upgrade works to fix the problem in the diff bush area... also the tailshaft centre bearing can be toast to cause a similar thud. Link to comment Share on other sites More sharing options...
EgoXR6Turbo Member 60 Member For: 6y 1m 11d Posted 16/06/20 07:10 PM Author Share Posted 16/06/20 07:10 PM Thanks mate centre bearing has been changed Same with tailshaft couplers/donuts. so the diff hat eliminates the thud completely even when snapping gears ? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 14d Gender: Male Location: Melbourne Posted 17/06/20 12:09 AM Share Posted 17/06/20 12:09 AM there's only so much lash the driveline can take, so if the sound emanates from the gearbox itself you can't eliminate it, but in terms of the rear end, yeah, it's heaps better. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 17/06/20 12:19 AM Share Posted 17/06/20 12:19 AM 11 hours ago, k31th said: also the tailshaft centre bearing can be toast to cause a similar thud. This happened with my territory recently. I replaced the centre bearing and no more thud. Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 9m 3d Posted 17/06/20 04:54 AM Share Posted 17/06/20 04:54 AM If your rear bush has voids it will thud. Throw a solid bush in it and see if it goes away. It will break bolts/hats asap though. Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,019 Member For: 9y 2d Gender: Male Location: Canberra ACT Posted 17/06/20 05:42 AM Share Posted 17/06/20 05:42 AM My ZF-equipped car is exactly the same despite everything being all good in the rear. You learn to ease off for a split second before completely jumping off the throttle when you are up it. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 14d Gender: Male Location: Melbourne Posted 17/06/20 05:48 AM Share Posted 17/06/20 05:48 AM didn't know you had the twin-bush upgraded diff hat, @El Andrew? Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,019 Member For: 9y 2d Gender: Male Location: Canberra ACT Posted 17/06/20 05:55 AM Share Posted 17/06/20 05:55 AM Nah I don't - got the original bush setup like OP. Just mean that it is normal that they clunk with a big lift off. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 14d Gender: Male Location: Melbourne Posted 17/06/20 06:02 AM Share Posted 17/06/20 06:02 AM fair enough Link to comment Share on other sites More sharing options...
