Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 25d Gender: Male Location: South Australia Posted 22/03/23 10:42 AM Author Share Posted 22/03/23 10:42 AM Nah haven't pulled the head off but while I was pulling the balancer I got an idea of the extent of the valve damage. There is still a bit of compression there so I expect most of the valves to be bent but not too much. I was decelerating when it let go and had it switched it off and into into neutral quick, so there should be minimal piston coating and valve seat damage. HP Junkie oil pump body is intact but cosmetically damaged. Atomic crank sprocket is toast, exhaust cam gear has a couple of chips on it but can still work, custom machined Atomic timing guide is fine, the alloy fixed guide is snapped at the base. I'll have to go through the oil pump to check nothing went through it and fingers crossed it's fine there. Bottom end, head and turbo etc will be fine, the filter would have picked up anything that went through the pump and the turbo has an extra filter. On the subject of the Atomic tensioner, there are wear marks on a couple of the teeth on the plunger, the spring lock has definitely been jumping over the teeth. Without the posi stop setup it would have failed much earlier. There is also significant marking on the inside of the timing cover where the M4? bolt has been backing out of the tensioner. There's only so much you can do with hardware that small. I have more to say on the matter but that'll do for now 1 2 Link to comment Share on other sites More sharing options...
Tom Tucker Donating Members 615 Member For: 4y 9m 25d Posted 22/03/23 08:27 PM Share Posted 22/03/23 08:27 PM Great diagnosis man, really useful info for others. Keen to hear your further thoughts Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 25d Gender: Male Location: South Australia Posted 22/03/23 11:43 PM Author Share Posted 22/03/23 11:43 PM 3 hours ago, Tom Tucker said: further thoughts Loctite everything, even your wheel nuts 2 Link to comment Share on other sites More sharing options...
BeerTurbo Donating Members 234 Member For: 5y 11m 15d Posted 22/03/23 11:44 PM Share Posted 22/03/23 11:44 PM + this is good advice, I allways Loctite my spark plugs. 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 25d Gender: Male Location: South Australia Posted 22/03/23 11:45 PM Author Share Posted 22/03/23 11:45 PM Gain an extra 20psi compression doing that Link to comment Share on other sites More sharing options...
Tom Tucker Donating Members 615 Member For: 4y 9m 25d Posted 23/03/23 03:16 AM Share Posted 23/03/23 03:16 AM I'm assuming you used loctite? Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 25d Gender: Male Location: South Australia Posted 23/03/23 03:35 AM Author Share Posted 23/03/23 03:35 AM You don't usually use loctite on the oil pump to block bolts, but in the case of revving the piss out of it, it might be worth doing. The bolts only get done up to 10nm so they may very well shear off trying to remove them, if they are loctited. In other news...me book arrived, I learnt one new thing that made no difference to the trans in the vehicle I'm currently tuning. 2 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,302 Member For: 16y 14d Gender: Male Location: Melbourne Posted 23/03/23 03:38 AM Share Posted 23/03/23 03:38 AM read the whole book already? that was quick... Link to comment Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,370 Member For: 5y 26d Gender: Male Location: Perth, WA Posted 23/03/23 03:38 AM Share Posted 23/03/23 03:38 AM 2 minutes ago, Puffwagon said: You don't usually use loctite on the oil pump to block bolts, but in the case of revving the piss out of it, it might be worth doing. The bolts only get done up to 10nm so they may very well shear off trying to remove them, if they are loctited. I remember hearing a bloke saying you should loctite everything, which would include these bolts Some good advice, he seems to know his sh*t 3 hours ago, Puffwagon said: Loctite everything, even your wheel nuts Link to comment Share on other sites More sharing options...
BeerTurbo Donating Members 234 Member For: 5y 11m 15d Posted 23/03/23 03:39 AM Share Posted 23/03/23 03:39 AM 3 minutes ago, Puffwagon said: You don't usually use loctite on the oil pump to block bolts, but in the case of revving the piss out of it, it might be worth doing. The bolts only get done up to 10nm so they may very well shear off trying to remove them, if they are loctited. In other news...me book arrived, I learnt one new thing that made no difference to the trans in the vehicle I'm currently tuning. is it worth the cost? everything I learnt about ZF's I learnt from you hahahaha Link to comment Share on other sites More sharing options...
