Puffwagon Puff Gold Donating Members 15,128 Member For: 9y 2m 27d Gender: Male Location: South Australia Posted 11/11/21 03:53 AM Author Share Posted 11/11/21 03:53 AM The intake charge is still cooled though not until it is closer to the port, but it will still be cooled down a sh*tload. The only benefit cooling wise for pre tb is that is would cool the manifold down, further cooling the intake air. I suppose I could install the jets further up the runners to give it more time to cool and also cool the runners more. Haha I also have 3 jets that I can install pre tb if I want to get hectic about it! 1 Link to comment Share on other sites More sharing options...
bjc Donating Members 2,812 Member For: 20y 7m 21d Gender: Male Location: Townsville Posted 11/11/21 03:34 PM Share Posted 11/11/21 03:34 PM I'm thinking also that the air temp sensors won't see this large drop in temperature so compensation won't take effect (mightn't be a big issue). Spare jets are good as they are one of the most expensive things in the kits... While I'm thinking... don't forget to dabble in/try out nitromethane also with the W/M injection. Unsure what the price is now but it was $20 a litre from hobby shops years ago unless you know someone who buys it by the drum! I'm pretty sure it's still sold in a bottle for the kits like Snow Performance premix (which isn't 50/50 the jews). It was called "hot shot" or something which is hilarious (for the men at least). You probably know but don't buy RC fuel as it contains synthetic and bean/castor oil. It smells phuking fantastic though... Lol Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,128 Member For: 9y 2m 27d Gender: Male Location: South Australia Posted 12/11/21 01:03 AM Author Share Posted 12/11/21 01:03 AM Yerp the tmap is just above the lower runners in the intake manifold and wouldn't get touched with port injection. This isn't an issue though as it can be adjusted in the tune and in my case is already adjusted to the usual settings. Haha I can't say whether I'll use nitro methane or not but it's unlikely. More likely though is using a methanol/98 mix in the tank to max out the injectors and use water meth on top of that. It's a while off though so who know?! 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,128 Member For: 9y 2m 27d Gender: Male Location: South Australia Posted 25/11/21 03:16 AM Author Share Posted 25/11/21 03:16 AM Gonna order an oil pump, which one should I get? https://www.golebysparts.com.au/search?q=barra* oil* pump*&type=article,page,product Link to comment Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,370 Member For: 5y 27d Gender: Male Location: Perth, WA Posted 25/11/21 03:24 AM Share Posted 25/11/21 03:24 AM MT, because its on sale and the cheapest billet option there lol Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,128 Member For: 9y 2m 27d Gender: Male Location: South Australia Posted 25/11/21 03:33 AM Author Share Posted 25/11/21 03:33 AM They're all within a few hundred dollars so price isn't a consideration. In saying that I'm not going a dry sump cos that sh*t is way too expensive! Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 25d Gender: Male Location: Adelaide Posted 25/11/21 04:21 AM Share Posted 25/11/21 04:21 AM I’ve been using the M/T oil pumps lately and they’re an amazing bit of billet ! If you want one Nathan I can sharpen that price up by a touch 2 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,128 Member For: 9y 2m 27d Gender: Male Location: South Australia Posted 25/11/21 04:36 AM Author Share Posted 25/11/21 04:36 AM (edited) Cheers mate, I literally just bought the hp junkie unit. One thing that steered me away from the Monsta Torque unit was the fact that it is advertised as OEM pressure, which is not something I want. Now looking at those pics I can see they actually do offer different relief settings. Oh well. Edited 25/11/21 05:02 AM by Puffwagon a word Link to comment Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,370 Member For: 5y 27d Gender: Male Location: Perth, WA Posted 25/11/21 04:40 AM Share Posted 25/11/21 04:40 AM 18 minutes ago, JETURBO said: I’ve been using the M/T oil pumps lately and they’re an amazing bit of billet ! If you want one Nathan I can sharpen that price up by a touch Damn that is one hot looking bit of kit 🤑😍 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,128 Member For: 9y 2m 27d Gender: Male Location: South Australia Posted 25/11/21 06:26 AM Author Share Posted 25/11/21 06:26 AM So yeah the money wasting continues... After spending nearly 10k between the trans and the water meth kit, the car lasted about 3 weeks before the oil pump exploded it's *beep* all through the timing cover and sump. This round of stuff I've ordered to get it up and running again lists thusly; Horse Power Junkie High Volume Barra Billet Oil Pump Atomic Heavy Duty Posi-Stop Barra DOHC Timing Chain Tensioner Atomic Barra Heavy Duty Timing Chain Atomic (Barra BA-FGX) Atomic billet steel crankshaft sprocket Atomic Solid Checking Lifter - Ford DOHC 6 Cylinder, DOHC V8 and V10 DOHC Modular Engine Dyno-Mite Performance BA-FGX Barra Fire Ring Gasket Kit in 39 thou Atomic Roller Rocker Set The billet crank is gonna have to wait cos I ain't made of money. Also gonna order bearings once the motor is apart cos I might not even need them, but also it might have farked a crank pin in which case I'll be using a ten under crank I have here. Will drop the head off to fix the cam journal and a quick skim and also pick up some strong ass acid to clean the cams. Gonna re-ring it while it's apart and close the second ring gap a teeny tiny bit from 28 down to 26 thou, leave the top at 22. Should help a little with blow by....maybe?! Anyway enough waffle, more updates will come eventually. 6 Link to comment Share on other sites More sharing options...
