Puffwagon Puff Gold Donating Members 15,117 Member For: 9y 2m 21d Gender: Male Location: South Australia Posted 10/04/21 11:02 AM Author Share Posted 10/04/21 11:02 AM (edited) So far I've taken off the rough surface with a carbide bur and have hit it with a 60 grit paper wheel. At this stage I'm not checking the flow but it might be something to do in the future. If you meant port matching, I'll be making sure the gaskets aren't intruding into the air flow and might have a quick check of the manifolds to make sure the isn't a step up for the air. As far as the difference it will make, I'm not sure. The barra ports are already well shaped but there is a rough surface that can be cleaned up, casting marks here and there and also a fairly decent bump right before the valve seat that I'm removing. I'm not expecting miracles but since I've got the head off I may as well put some time into cleaning it up. Edited 10/04/21 11:06 AM by Puffwagon Just cos 4 Link to comment Share on other sites More sharing options...
bjc Donating Members 2,812 Member For: 20y 7m 16d Gender: Male Location: Townsville Posted 10/04/21 11:51 AM Share Posted 10/04/21 11:51 AM Can't remember if I put this here before... Pretty sure I got that off a Territory group on Facebook. Exhaust side obviously and he only matched the gasket to the port size (not enlarging the ports) fwiw. 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,117 Member For: 9y 2m 21d Gender: Male Location: South Australia Posted 12/04/21 12:32 PM Author Share Posted 12/04/21 12:32 PM All farken righty then... Cams Vernier gears Finished porting the head and the exhaust gasket. I didn't go all out and cut down the exhaust guides cos I cbf. You can see where the previous gasket was pushing water when the boost was wound up. 6 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,117 Member For: 9y 2m 21d Gender: Male Location: South Australia Posted 15/04/21 11:43 AM Author Share Posted 15/04/21 11:43 AM Trial fitting cams. Apart from that just doing some cleaning. Bleh And yes they are back to front 2 Link to comment Share on other sites More sharing options...
NA_TURBO Member 532 Member For: 8y 6m 11d Gender: Male Location: Mildura Posted 15/04/21 01:24 PM Share Posted 15/04/21 01:24 PM More Powa! Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,117 Member For: 9y 2m 21d Gender: Male Location: South Australia Posted 15/04/21 01:52 PM Author Share Posted 15/04/21 01:52 PM It'll be some power Link to comment Share on other sites More sharing options...
boakesautomarine Member 49 Member For: 4y 1m 8d Posted 15/04/21 10:01 PM Share Posted 15/04/21 10:01 PM Danggg it 😂 your making me what to put those exact cams in and ported head Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,117 Member For: 9y 2m 21d Gender: Male Location: South Australia Posted 16/04/21 03:53 AM Author Share Posted 16/04/21 03:53 AM Wait till I get some results to see if it's worth it. It's not a cheap or quick exercise to get done and I only did it cos I was pulling the head off anyway. Link to comment Share on other sites More sharing options...
bjc Donating Members 2,812 Member For: 20y 7m 16d Gender: Male Location: Townsville Posted 16/04/21 12:30 PM Share Posted 16/04/21 12:30 PM Is there any way to notch the timing cover so it's not a mission to set the cam timing when you want to change/test?Similar to those spankers with those JZ engine thingies... Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,117 Member For: 9y 2m 21d Gender: Male Location: South Australia Posted 16/04/21 12:37 PM Author Share Posted 16/04/21 12:37 PM Yeah I was discussing this the other day. I reckon it would be a piece of piss to chop up a rocker cover and make a window. 1 Link to comment Share on other sites More sharing options...
