bjc Donating Members 2,812 Member For: 20y 7m 21d Gender: Male Location: Townsville Posted 19/02/21 01:18 AM Share Posted 19/02/21 01:18 AM Seems my memory is worse than I thought... It's the front two screws I've used the washers on (last picture for the close up).1st is looking straight at the scoop, it sits slightly proud but I couldn't do anything to fix this! 2nd is the two screws either side which were the ones that turned to dust on my first scoop. So brittle!I'll try and find a pic of when I had no scoop and just plastidipped it. 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 20/02/21 02:53 AM Author Share Posted 20/02/21 02:53 AM Emptied the bong water out of the catch can today. Fitted the alloy header tank. Fixed my windscreen washer pump seal. I fixed the fuel a bit on the dyno last night and it ran up 602awkw on 32psi at the tip. Went to launch it today and the farken gfb recirc valve fell apart. I found the spring and plunger on the side of the road and the top was still attached to the vac hose. Hopefully that's the end of sh*t falling off or breaking for a while 1 1 Link to comment Share on other sites More sharing options...
Tom Tucker Donating Members 615 Member For: 4y 9m 25d Posted 20/02/21 06:15 AM Share Posted 20/02/21 06:15 AM I like your optimism haha 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 20/02/21 11:38 AM Author Share Posted 20/02/21 11:38 AM I try to keep a balance between optimistic and realistic. That usually means things go well...unless they don't. 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 22/02/21 08:15 AM Author Share Posted 22/02/21 08:15 AM Welded another O2 bung into the dump this afternoon. Now I have a wideband and the stock narrowband in place. The trans is getting less happy by the day so that's the next thing I'm gunna have a crack at. Also had a 3 inch alloy bend arrive in the post but I probably should have bought a 2.5 inch. Oh well I guess I can go with the 3 inch for the turbo outlet. 4 Link to comment Share on other sites More sharing options...
bjc Donating Members 2,812 Member For: 20y 7m 21d Gender: Male Location: Townsville Posted 23/02/21 08:14 AM Share Posted 23/02/21 08:14 AM Why don't you use the post cat O2 port for your wideband and give the flick to the current sensor that's there?I'm still looking for that no scoop bonnet pic also... Only 1200 odd more pics to go! Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 23/02/21 08:48 AM Author Share Posted 23/02/21 08:48 AM I've got a custom 4 inch exhaust, hand made from the turbo back. There aren't O2 bungs unless I put them there. It's working pretty good now that both sensors are in there. Meh the scoop hole looks like a robot pussy that has done the rounds on a Saturday night. 1 1 Link to comment Share on other sites More sharing options...
bjc Donating Members 2,812 Member For: 20y 7m 21d Gender: Male Location: Townsville Posted 23/02/21 09:19 AM Share Posted 23/02/21 09:19 AM That's what you get for running on 2hrs sleep... Totally forgot the huge zorst! 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 23/02/21 09:31 AM Author Share Posted 23/02/21 09:31 AM Yeah it's pretty good now. It's quiet enough to daily drive yet it flows enough for 1000hp. 1 Link to comment Share on other sites More sharing options...
Tom Tucker Donating Members 615 Member For: 4y 9m 25d Posted 23/02/21 09:47 PM Share Posted 23/02/21 09:47 PM Does it have a centre muffler or just a big rear muffler? Link to comment Share on other sites More sharing options...
