BeerTurbo Donating Members 234 Member For: 5y 11m 9d Posted 12/02/21 05:04 AM Share Posted 12/02/21 05:04 AM I know for me as a basic home welder guy, I dont purge tubes so my ss tubes get a little suggaring inside. that would afect the airflow . if you purge and the pipes are smooth than the airflow between the pipes would be fine. you can buy the fg coil plugs, cut of the b series one and crimp on the fg ones. I bought some when I was going to do the conversion. so I have the plugs, but no coil cover or coils...hahaha Link to comment Share on other sites More sharing options...
bjc Donating Members 2,812 Member For: 20y 7m 14d Gender: Male Location: Townsville Posted 12/02/21 05:28 AM Share Posted 12/02/21 05:28 AM I don't think mine were purge welded (who gives a hoot really!) but the welds look like no filler was used... I really would like a 3in1 welder to learn plus bodge up anything needed. I depinned (unpinned?) the injector plugs on my BA back when Eugene injectors were popular. No issues and then reversed them back to OEM plugs for the 60lb Siemens.Long story short...if the pins are the same then surely the plugs only can be swapped instead of cutting and open barrel splice, ferrule or soldering? Link to comment Share on other sites More sharing options...
BeerTurbo Donating Members 234 Member For: 5y 11m 9d Posted 12/02/21 05:31 AM Share Posted 12/02/21 05:31 AM you can weld ss nicely without filler and if you good with the amps there will be little to no sugaring on the inside. ive seens ome paste people use on the inside of a join, like a flux core to stop suggaring without purging. 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,115 Member For: 9y 2m 20d Gender: Male Location: South Australia Posted 12/02/21 07:26 AM Author Share Posted 12/02/21 07:26 AM I've got coil plugs coming with the rocker cover.I'm not sure if the pins are the same but it'll be worth a look. That'll be next weekend's job. I'm putting the car on the dyno tomorrow to see how far I can take it. I'm not sure how much it'll make but it'll be something 2 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,115 Member For: 9y 2m 20d Gender: Male Location: South Australia Posted 13/02/21 04:24 AM Author Share Posted 13/02/21 04:24 AM Did some tuning today. Apparently gapping the plugs did the trick cos straight away it ran up 605awkw with no tune changes. I frigged around with fuel and boost and this and that, and managed 685awkw at 39.5psi. I brought it in gently as the trans wasn't happy to take much more than 30psi on the hit. There was some trans truncation going on at that power level on the road, so I've turned it back down to about 640awkw for now. 7 3 Link to comment Share on other sites More sharing options...
BeerTurbo Donating Members 234 Member For: 5y 11m 9d Posted 13/02/21 04:28 AM Share Posted 13/02/21 04:28 AM niceeee...have u run a quarter in this since its been above 550kw? bet it farken moves Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,115 Member For: 9y 2m 20d Gender: Male Location: South Australia Posted 13/02/21 04:31 AM Author Share Posted 13/02/21 04:31 AM Nah no quarter mile here atm. I went roll racing with 503awkw. Now 4th gear feels like 2nd gear. 1 Link to comment Share on other sites More sharing options...
Tom Tucker Donating Members 614 Member For: 4y 9m 19d Posted 13/02/21 06:26 AM Share Posted 13/02/21 06:26 AM Damn! Staunch numbers man, and awesome to see someone doing it all themselves. Sorry if you've mentioned already, but what sort of built engine are you running? Any issues with the head lifting at near 40psi? What valve springs? Link to comment Share on other sites More sharing options...
MBAF Bronze Donating Members 2,156 Member For: 7y 8m 3d Posted 13/02/21 06:38 AM Share Posted 13/02/21 06:38 AM Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,115 Member For: 9y 2m 20d Gender: Male Location: South Australia Posted 13/02/21 06:43 AM Author Share Posted 13/02/21 06:43 AM The engine details are in the first page of the thread. It's a 2005 na territory bottom end with mods. It looks like it pushed a bit of water a few times but that will be dealt with in a couple of weeks. That's not the head lifting but rather the gasket leaking, as it has 12mm arp studs and oversize washers. They say not to use sealant on the gasket but that is a load of bollocks! Either just going to do a reseal or machine the block in situ and install 14mm head studs. Probably just do a reseal for now, although I'll be a bit annoyed having to do all the work again if it doesn't hold up! The valve springs are Crow VTKBA6T-24 Pics of the graphs are on the previous page @MBAF 1 Link to comment Share on other sites More sharing options...
