JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 9m 26d Gender: Male Location: Adelaide Posted 06/08/20 04:14 AM Share Posted 06/08/20 04:14 AM What oil did you use ? Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,045 Member For: 9y 1m 28d Gender: Male Location: South Australia Posted 06/08/20 04:27 AM Author Share Posted 06/08/20 04:27 AM Penrite bmv. I got 4 litres into the trans and it said nope. I've picked up a couple of bottles transmax and at $108 for 4 litres I hope it works a bit better. Link to comment Share on other sites More sharing options...
Romulus Donating Members 1,279 Member For: 19y 2m 24d Location: Perth Posted 06/08/20 04:29 AM Share Posted 06/08/20 04:29 AM You might have to flush the trans a couple of time to dilute the other oil that's in it. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,045 Member For: 9y 1m 28d Gender: Male Location: South Australia Posted 06/08/20 04:35 AM Author Share Posted 06/08/20 04:35 AM Yep I'll do that and get all 8 litres into it. 1 Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 2d Gender: Male Location: Perth Posted 06/08/20 06:10 AM Share Posted 06/08/20 06:10 AM Should have bought 20L of gulf western ts-10 $160 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,045 Member For: 9y 1m 28d Gender: Male Location: South Australia Posted 06/08/20 06:20 AM Author Share Posted 06/08/20 06:20 AM There's always next time. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,045 Member For: 9y 1m 28d Gender: Male Location: South Australia Posted 06/08/20 06:37 AM Author Share Posted 06/08/20 06:37 AM I spose I could return the Castrol and get some GW. It's a bit of a drive but that's not the end of the world. Link to comment Share on other sites More sharing options...
adams355 Member 529 Member For: 6y 10m 27d Gender: Male Location: Brisbane Posted 06/08/20 08:03 AM Share Posted 06/08/20 08:03 AM Ive have had these dramas lately, unless you flush it you won't get it all back in there. I don't flush mine though, but have found filling and running gears 3-4 times at around 40 C fluid temp gets most in there. Also, a quick easy drive and letting sit a night and I can usually get at least 500ml plus in when its just starting to warm up. I doubt its the fluid even though I do use the Gulf Western SYN TS as well. 1 Link to comment Share on other sites More sharing options...
violetpop Silver Donating Members 436 Member For: 4y 3m 20d Posted 06/08/20 08:40 AM Share Posted 06/08/20 08:40 AM Wonder if you are having the same issue as I had with the filter not sitting correctly after doing the steel pan conversion? Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,045 Member For: 9y 1m 28d Gender: Male Location: South Australia Posted 06/08/20 09:00 AM Author Share Posted 06/08/20 09:00 AM I've just gone out to the shed and measured the oil that came out of the trans. I put a full 4 litre bottle into it after dropping it and this is the level of the old oil, plus 200ml of extra fluid from the pump that I tipped in the drain pan. My thumb is at the 3 litre mark. I think it could still be a touch low, given this picture. I made sure the filter was in and up properly with no old seal left behind. I'll drop it again tomorrow, mod the filter intake and see how I get on. The steel pan filter intake is roughly half the stock size and I've heard of transmissions not working well due to aftermarket filter restrictions. Link to comment Share on other sites More sharing options...
