k31th less WHY; more WOT Site Developer 28,302 Member For: 16y 13d Gender: Male Location: Melbourne Posted 21/06/20 05:03 AM Share Posted 21/06/20 05:03 AM looks good 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 25d Gender: Male Location: South Australia Posted 21/06/20 05:15 AM Author Share Posted 21/06/20 05:15 AM Well I pulled the trigger, so all going well will have coils, plugs and breather system ruled out for falling over causes. 1 Link to comment Share on other sites More sharing options...
Typhoon Member 564 Member For: 19y 7m Gender: Male Posted 21/06/20 11:28 AM Share Posted 21/06/20 11:28 AM Log cam angel vs target. I had a dead cam phaser which caused the symptoms you’ve described. 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 25d Gender: Male Location: South Australia Posted 21/06/20 11:07 PM Author Share Posted 21/06/20 11:07 PM I've just had a look through a log and it's showing both cams staying at -10 no matter where the rpm or load is. The cam error is mostly less than 1 degree but occasionally a bit more, regardless of rpm and load. Anyhow I've got another set of solenoids and phasers here so I'll see what happens when I swap them. Link to comment Share on other sites More sharing options...
Typhoon Member 564 Member For: 19y 7m Gender: Male Posted 21/06/20 11:23 PM Share Posted 21/06/20 11:23 PM So to have both Phasers fail together is less likely but possible and would show a static angle as described. Start with the solenoids first. The cam angle should vary more than -10 for sure. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 25d Gender: Male Location: South Australia Posted 21/06/20 11:32 PM Author Share Posted 21/06/20 11:32 PM Yep for sure. The solenoids are a pretty quick thing to do. Only thing now is to get out there and start checking stuff. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 25d Gender: Male Location: South Australia Posted 22/06/20 12:24 AM Author Share Posted 22/06/20 12:24 AM Well it ain't the solenoids. Link to comment Share on other sites More sharing options...
Typhoon Member 564 Member For: 19y 7m Gender: Male Posted 22/06/20 12:32 AM Share Posted 22/06/20 12:32 AM Replacing both Phasers is a bit of work. Ensure no oil flow restrictions to the phasers first. Inspect cam caps on top of each phasers for blockages. Obviously the OCV screens were clean. Phasers can make noise when they are stuck too. Good luck mate 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 25d Gender: Male Location: South Australia Posted 22/06/20 02:02 AM Author Share Posted 22/06/20 02:02 AM Well as much as I didn't want to leave an update like this, here it is anyway. Exhaust cam is toast, intake cam is fine. Will be pulling the engine to assess any further damage. 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,302 Member For: 16y 13d Gender: Male Location: Melbourne Posted 22/06/20 03:13 AM Share Posted 22/06/20 03:13 AM ouch... not good news for the exhaust cam... hopefully the damage is limited to the exhaust cam, though. Link to comment Share on other sites More sharing options...
