Foxsayss New Member 3 Member For: 3y 10m 23d Posted 01/06/20 09:20 PM Share Posted 01/06/20 09:20 PM Hey , ive got a BF turbo ute the battery light stays on when the car is running, the guy I purchased it from said it's done it the whole time he's had it and never drained a battery, lately its been flashing off and on when pulling up to lights or round about and the engine pulses with the light . Any ideas Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 14d Gender: Male Location: Melbourne Posted 02/06/20 01:12 AM Share Posted 02/06/20 01:12 AM that light is meant to indicate that charging via the alternator is failing... but if the previous owner is telling the truth, then it'll be the sensor for the "charge indicator light" that's failed or the alternator is overcharging. Link to comment Share on other sites More sharing options...
Foxsayss New Member 3 Member For: 3y 10m 23d Posted 28/06/20 09:03 AM Author Share Posted 28/06/20 09:03 AM Ended up getting a flat after not starting it for a couple of days , got a new battery getting 14.4v coming back to the battery, light is still on in cluster , now my reading light work sporadically like if I've got it on accessories it will come on when the window goes down. Could this have something to do with my ignition ? because I've got to turn it back a notch after starting it Link to comment Share on other sites More sharing options...
Foxsayss New Member 3 Member For: 3y 10m 23d Posted 10/11/20 02:56 PM Author Share Posted 10/11/20 02:56 PM Solved was a poor connection on the alternator cable was damaged and bare wire was showing Link to comment Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 10y 29d Posted 10/11/20 06:52 PM Share Posted 10/11/20 06:52 PM good that you sorted that but change the ignition switch before it fails completely (the back falls off) another column or repair kit Link to comment Share on other sites More sharing options...
