Walbro 525
  • ...JD TUNING ADELAIDE...
  • Member For: 15y 10m 16d
Honestly I don’t know... haven’t been a big fan of DW’s in the past but I haven’t used the new one personally so it could be the new best thing !
be mindful the Walbro ratings are always honest and boosting a 525 to 18-20v would push it well into the 600’s too
Edited by JETURBO
  • Silver Donating Members
  • Member For: 10y 2m 4d
@JETURBO guessing a 525 would be a no-brainer as a lift pump feeding dual pierburgs?
Edit
I notice plaz only sells the 535 / F90000295 without the check valve, no good for standard application, correct?
Edited by camo86T
It’s actually imho way too big as a lift for the effort involved to fit it
a Walbro 400 E85 pump requires zero wiring upgrades and will supply feed to a surge in great volumes.
remember surge pumps return to surge so it’s not required to have a massive lift pump
Fuel starve on a dyno is typically due to the rail emptying due to outgoing pumps not keeping up ... Typically not an empty surge.
This caters for 99% of all applications... a full race circuit car is a different story and would benefit from as big of a lift pump as you can get
  • Dropping a turd
  • Member For: 16y 5m 20d
Edit
This is all you need for e85 lift pump.
https://www.tiperformance.com.au/products/walbro-250lph-fuel-pump-kit-e85-f10000302/
Hypothetically, if you wanted to wanted to go all out to avoid heating of fuel would it be possible to run return to main tank and have a big arse lift pump
or plain not practical?
@Romulus apologies for hijacking thread
Weren't you M6 something something before?
Stink hole has a point and I use smaller lift pumps for single Pierbergs
but for twins I go the biggest without having to do crazy extra stuff just to make work correctly
