Romulus Donating Members 1,279 Member For: 19y 3m 19d Location: Perth Posted 30/05/20 10:30 AM Share Posted 30/05/20 10:30 AM Anyone tried the Walbro 525LPH pump? How much power is it supporting on E85? TIA. Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 23d Gender: Male Location: Adelaide Posted 31/05/20 05:13 AM Share Posted 31/05/20 05:13 AM General consensus is 470-480rwkw on Lambda 0.8 with wiring/relay upgrade 1 Link to comment Share on other sites More sharing options...
Romulus Donating Members 1,279 Member For: 19y 3m 19d Location: Perth Posted 31/05/20 09:31 AM Author Share Posted 31/05/20 09:31 AM What's your opinion on the new brushless DW440? With a voltage booster it will flow 620LPH @ 20v. Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 23d Gender: Male Location: Adelaide Posted 31/05/20 10:46 AM Share Posted 31/05/20 10:46 AM (edited) Honestly I don’t know... haven’t been a big fan of DW’s in the past but I haven’t used the new one personally so it could be the new best thing ! be mindful the Walbro ratings are always honest and boosting a 525 to 18-20v would push it well into the 600’s too Edited 31/05/20 10:47 AM by JETURBO Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 10y 2m 11d Gender: Male Location: SW Sydney Posted 01/06/20 02:45 AM Share Posted 01/06/20 02:45 AM (edited) @JETURBO guessing a 525 would be a no-brainer as a lift pump feeding dual pierburgs? Edit I notice plaz only sells the 535 / F90000295 without the check valve, no good for standard application, correct? Edited 01/06/20 02:56 AM by camo86T Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 23d Gender: Male Location: Adelaide Posted 01/06/20 02:55 AM Share Posted 01/06/20 02:55 AM It’s actually imho way too big as a lift for the effort involved to fit it a Walbro 400 E85 pump requires zero wiring upgrades and will supply feed to a surge in great volumes. remember surge pumps return to surge so it’s not required to have a massive lift pump Fuel starve on a dyno is typically due to the rail emptying due to outgoing pumps not keeping up ... Typically not an empty surge. This caters for 99% of all applications... a full race circuit car is a different story and would benefit from as big of a lift pump as you can get 1 Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 10y 2m 11d Gender: Male Location: SW Sydney Posted 01/06/20 02:59 AM Share Posted 01/06/20 02:59 AM cheers bud Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 27d Gender: Male Location: Perth Posted 01/06/20 03:02 AM Share Posted 01/06/20 03:02 AM 16 minutes ago, camo86T said: @JETURBO guessing a 525 would be a no-brainer as a lift pump feeding dual pierburgs? Edit I notice plaz only sells the 535 / F90000295 without the check valve, no good for standard application, correct? This is all you need for e85 lift pump. https://www.tiperformance.com.au/products/walbro-250lph-fuel-pump-kit-e85-f10000302/ Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 10y 2m 11d Gender: Male Location: SW Sydney Posted 01/06/20 03:07 AM Share Posted 01/06/20 03:07 AM Hypothetically, if you wanted to wanted to go all out to avoid heating of fuel would it be possible to run return to main tank and have a big arse lift pump or plain not practical? @Romulus apologies for hijacking thread Weren't you M6 something something before? Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 23d Gender: Male Location: Adelaide Posted 01/06/20 03:10 AM Share Posted 01/06/20 03:10 AM Stink hole has a point and I use smaller lift pumps for single Pierbergs but for twins I go the biggest without having to do crazy extra stuff just to make work correctly Link to comment Share on other sites More sharing options...
