Fg f6 over boosting
Regany
  • Member For: 4y 9m 25d
Hi guys, cars been at the tuners for a over 2 weeks now the car is having a problem with over boosting we have taken off the turbo (3582r) and have got the turbo ported and new flapper but it's still boost spiking we have tried all the obvious reasons and have no idea why it's doing it the actuator is a 12psi turbosmart any information would be greatly appreciated cheers
We did that before we ported out the turbo and it spiked.  next thing we are going to try is different springs but I doubt that'll change it the springs it has in it equal to 12psi but arnt the combination that are on the chart turbo smart give you as a combination for 12psi so I'm not sure if it's that or not
  • less WHY; more WOT
  • Site Developer
  • Member For: 15y 11m 18d
if it spikes on the stock actuator with the boost solenoid bypassed, then you have a mechanical problem... the wastegate is either getting stuck closed (or not opening correctly) the actuator isn't setup correctly (pre-load etc).
  • Site Developer
just put the stock actuator back on and check it with a compressor to ensure it opens the flap completely at about 10-12psi or so, then plumb the actuator directly to the front of the turbo and see if it overboosts. If it still overboosts in that sort of situation, the only way for it to happen is for your wastegate to be stuck closed mechanically in some way shape or form.
