bourbon New Member 1 Member For: 3y 11m 5d Posted 20/05/20 01:38 AM Share Posted 20/05/20 01:38 AM I've recently bought a ba xr6. It's had a few mods done under the bonnet . One I don't know why is the thermo fans are hard wired to run all the time,so as soon as car is started fans operate. The temp gauge doesn't work at all at any engine temp and red temp light comes on after a few minutes of running. Coolant level is correct and engine is not over heating / running hot . Im wondering if rewiring the fans has had an effect on temp gauge,any thoughts would be greatly appreciated. I got out of the mechanics caper 23 years ago and do not have much knowledge when it comes to late model electrics. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 20/05/20 02:27 AM Share Posted 20/05/20 02:27 AM wiring the fans on wouldn't cause a temperature warning light, but might have been a dodgy workaround to a temperature problem manifesting. if the temperature gauge doesn't work at all, then you've got a different problem that should surely be fixed by replacing the relevant sensor. 1 Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,019 Member For: 9y 2d Gender: Male Location: Canberra ACT Posted 20/05/20 03:52 AM Share Posted 20/05/20 03:52 AM You'd think maybe the cylinder head temp sensor was dead, preventing the gauge working and preventing the PCM from switching on the fans. Previous owner then hard wired the fans as a work around. Light is probably coming on once the PCM realises it isn't getting a valid signal from the CHT sensor as the temp isn't increasing. 1 1 Link to comment Share on other sites More sharing options...
