RNUMUK New Member 12 Member For: 3y 11m 9d Posted 12/05/20 10:13 PM Author Share Posted 12/05/20 10:13 PM Thanks for all your advice and info. I have started to make some progress with tuning, still struggling to regulate boost as I'm running a 4 port solenoid which I'll be changing to a 3 port to simplify things. The best so far is 620hp - 820nm at 21psi. Once the boost is sorted I can then get some more boost in her(29psi max) and fine tune the fuel map. Hoping to see over 800hp. Will keep you posted. 1 Link to comment Share on other sites More sharing options...
finnas Gold Donating Members 105 Member For: 14y 3m 7d Posted 13/05/20 01:12 AM Share Posted 13/05/20 01:12 AM Nice work so far. How's your boost holding. flat to redline, dropping off? Where did you start losing power with spark? There's a point it will rollover but wont knock on E85. Anywhere between 13-17*. Just interested to compare a built motor to a stock one :) Link to comment Share on other sites More sharing options...
GAS41T Member 39 Member For: 8y 7m 21d Posted 13/05/20 03:01 AM Share Posted 13/05/20 03:01 AM Great build ... not a fan of the water/air intercooler from past experience....looks to small for one !!! This was my setup from 10yr ago on a rotary.... I also had an ice box but only was efficient for drag racing ....I found soon as your engine temp climbes so does your air temps = danger ... But with E85 it maybe more efficient than 10yr ago with no e85 about good luck with your tune Link to comment Share on other sites More sharing options...
RNUMUK New Member 12 Member For: 3y 11m 9d Posted 13/05/20 09:46 PM Author Share Posted 13/05/20 09:46 PM The problem you were experiencing is quite common with rotaries.........your engine was down on 6 pistons On 13/05/2020 at 11:12 AM, finnas said: Nice work so far. How's your boost holding. flat to redline, dropping off? Where did you start losing power with spark? There's a point it will rollover but wont knock on E85. Anywhere between 13-17*. Just interested to compare a built motor to a stock one I have just managed to get the boost control to regulate at 21psi through the rev range, coming on at 2700 and holding.......4 port has been quite tricky. from 16-18degrees it increased by 40kw which is an indication it could take more timing - can't quite remember torque without pulling the screen up. At this point it was making 620 hp and 850nm. Just need to now work on upping and holding boost at 28psi to continue to tune. 1 Link to comment Share on other sites More sharing options...
eff xr6t Member 569 Member For: 10y 6m 20d Posted 14/05/20 01:08 AM Share Posted 14/05/20 01:08 AM What springs have you got in the wastegate? I would personally keep the 4 port solenoid as changing to a 3 port is a downgrade. I run a 4 port and can get perfect control from my 15 psi spring pressure to what ever I could want without a problem. Link to comment Share on other sites More sharing options...
RNUMUK New Member 12 Member For: 3y 11m 9d Posted 14/05/20 01:25 AM Author Share Posted 14/05/20 01:25 AM Interesting, I've had conflicting opinions which started from one of the guys at Haltech stating that I'll "forever be chasing my tail trying to get it right" where another firend of mine has told me the same thing you did. I know think it's lack of experience on my behalf and will definitely persist with the 4 port. Any hints will be appreciated. 14 psi spring in wastegate Link to comment Share on other sites More sharing options...
Chevbarra New Member 2 Member For: 3y 11m 11d Posted 14/05/20 01:34 PM Share Posted 14/05/20 01:34 PM Can you post duty table? Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 8m 29d Posted 16/05/20 01:36 AM Share Posted 16/05/20 01:36 AM 100 bottom to top Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,291 Member For: 16y 9d Gender: Male Location: Melbourne Posted 16/05/20 01:46 AM Share Posted 16/05/20 01:46 AM hahah good suggestion... Link to comment Share on other sites More sharing options...
