RNUMUK New Member 12 Member For: 3y 11m 10d Posted 10/05/20 01:20 AM Share Posted 10/05/20 01:20 AM (edited) Hi all, I’m new to the forum and have started up my bf atomic built Barra in a Te cortina. I have this on the dyno and I’m not real sure on ignition timing since my Backround mechanical knowledge is in the diesel field. Mods are listed below: Atomic built 698kw engine bosch 2200cc injectors twin Bosch 535 running E85 precision 76/75 PWR W2A cooler FG intake custom exhaust manifold turbosmart 60mm waste gate turbosmart bov 2 speed glide 4500 stall 3:5 9inch any help would be appreciated. Any tuning tips especially with timing. Thanks in advance. Edited 10/05/20 01:21 AM by RNUMUK Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 8m 30d Posted 10/05/20 02:08 AM Share Posted 10/05/20 02:08 AM No tuna, but I'd start around 8-10 and keep adding till it stops making power. Be interested to see where you get to. Be surprised if it takes any more then 14 in the mid, and 17 up top Again I'm not a tuna, just logging cars and talking to people. Link to comment Share on other sites More sharing options...
RNUMUK New Member 12 Member For: 3y 11m 10d Posted 10/05/20 02:27 AM Author Share Posted 10/05/20 02:27 AM Thanks for the reply and info. Any other ideas/suggestions would be appreciated. I’m trying to have a base limit from responses to avoid maybe overcooking it and sound damage. First time dyno and petrol tuner. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 10d Gender: Male Location: Melbourne Posted 10/05/20 03:33 AM Share Posted 10/05/20 03:33 AM You're going to have a decent uphill battle with regard to gaining knowledge on this tuning platform. Have a read of this thread for an idea on what you'll need to know in terms of basics: https://www.fordxr6turbo.com/forum/topic/84077-jets-tuning-oh-no/ Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 8m 30d Posted 10/05/20 03:57 AM Share Posted 10/05/20 03:57 AM E85 isn't petrol as well. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 10d Gender: Male Location: Melbourne Posted 10/05/20 04:03 AM Share Posted 10/05/20 04:03 AM 15% of it is Link to comment Share on other sites More sharing options...
RNUMUK New Member 12 Member For: 3y 11m 10d Posted 10/05/20 04:09 AM Author Share Posted 10/05/20 04:09 AM Thanks for the info gents, I haven’t given all the info as this is my first time posting. tuning platform is an haltech elite 2500 and my tuning Backround is diesel and still fairly limited. I’ll post some pictures of the car Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 8m 30d Posted 10/05/20 04:56 AM Share Posted 10/05/20 04:56 AM You will target a slightly different afr then diesel Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 20d Gender: Male Location: Adelaide Posted 10/05/20 07:06 AM Share Posted 10/05/20 07:06 AM The fact you’ve asked the question means you’re far away from realising this isn’t a question you can actually ask but a result you will generate. This will give you some idea you have loads of research in front of you before you even think about taking to the Dyno. Everyone starts somewhere and the way you’ve asked the question means you are really unaware vs someone who knows but is fishing for data Google how to correctly set up timing scales/maps and hardware required to do so. The Haltech platform has a neat logger but don’t be fooled thinking it’s a Genuine Knock tuning tool but more of a tool to reduce timing on a knock event and threshold of limits more so After 30 solid minutes of google you’ll know why but the BARRA is unique and the Haltech ESP software is only as good as you are so definitely engage with a tune shop whose willing to help you or even set it up for you first 1 Link to comment Share on other sites More sharing options...
RNUMUK New Member 12 Member For: 3y 11m 10d Posted 10/05/20 07:47 AM Author Share Posted 10/05/20 07:47 AM Totally agree with trying to get help through a tune shop. I have my own dyno and would like to get this process done on my own.....even with paid help from a tune shop. Unfortunately it seems like it’s majic they’re not willing to give the secret to. I understand that you tune using the MBT method starting from a safe 10 degrees or less under boost. At the moment I am tuning to 26psi and have changed timing from 12 to 14 with no change at all with afr at 7 the whole way through the rev range which I think is bang on however no increase in power or torque. No knock since fuel is E85 but am assuming that it should be able to take more timing. So instead of possibly “sending Rodney to the moon” I’m trying to get some other examples of timing to ensure that is where my max timing advance is. It just seems low with E85. Link to comment Share on other sites More sharing options...
