smokingcold New Member 4 Member For: 4y 10d Posted 07/05/20 09:29 AM Share Posted 07/05/20 09:29 AM For a BA N/a to Turbo conversion using all factory gear. Would getting the PCM flashed to the stock turbo tune via SCT/HPTuners/PCMtec with an independent boost controller (bleed valve), Turbo Logic turned off and a 2 bar MAP sensor have any issues? My understanding is that Turbo Logic is the factory boost control option using the boost pressure sensor in the piping and solenoid for the wastegate which requires extra wiring etc. that I don't have. Around how much would it cost to flash the PCM to the factory program? I know a full custom dyno tune is the best choice but don't have the coin yet and dont want to lean it out on an NA tune and map sensor Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,298 Member For: 16y 13d Gender: Male Location: Melbourne Posted 07/05/20 10:10 AM Share Posted 07/05/20 10:10 AM There's no point doing anything like you've suggested without the money to replace the motor as even if you get it running for your "lack of coin" then you'll be lunching the motor in no time at all. Sell up and buy a turbo vehicle. 1 Link to comment Share on other sites More sharing options...
smokingcold New Member 4 Member For: 4y 10d Posted 07/05/20 12:23 PM Author Share Posted 07/05/20 12:23 PM So even with the turbo strategy it'll ping its head off? itll be sad if every WOT the knock sensor makes the ecu pull all the timing out lol I've heard of people going that way with success, so I think itll work for the months until I get a dyno tune Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,298 Member For: 16y 13d Gender: Male Location: Melbourne Posted 07/05/20 12:29 PM Share Posted 07/05/20 12:29 PM basically, yes... higher compression N/A motor means it'll ping without a proper tune. 1 Link to comment Share on other sites More sharing options...
smokingcold New Member 4 Member For: 4y 10d Posted 07/05/20 01:08 PM Author Share Posted 07/05/20 01:08 PM Thanks for the help k31th, Ive had a little play on hptuners looking at the differences between the BA na & turbo tunes and it seems they have different knock detection tables etc. which I hope will compensate for the high comp a bit. I would feel better if there was a way to dial in a slight retard, will an sct xcal x4 be able to adjust this post-tune? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,298 Member For: 16y 13d Gender: Male Location: Melbourne Posted 07/05/20 01:13 PM Share Posted 07/05/20 01:13 PM you need to do a lot of reading haha you're right at the start point. the xcal4 is just a handset that allows you to change tunes yourself and put it back to factory tune. it requires somebody with SCT tuning ability to do any tuning for you. hptuners can just flash the pcm with a custom tune. 1 Link to comment Share on other sites More sharing options...
BeerTurbo Donating Members 234 Member For: 5y 11m 14d Posted 07/05/20 01:20 PM Share Posted 07/05/20 01:20 PM 58 minutes ago, k31th said: basically, yes... higher compression N/A motor means it'll ping without a proper tune. dont forget it will melt those pissy valves on normal petrol eventually 20 minutes ago, smokingcold said: Thanks for the help k31th, Ive had a little play on hptuners looking at the differences between the BA na & turbo tunes and it seems they have different knock detection tables etc. which I hope will compensate for the high comp a bit. I would feel better if there was a way to dial in a slight retard, will an sct xcal x4 be able to adjust this post-tune? stock falcon ecm is going to detect knock events and do some retarding, if it sees lots of events it will also do a more permanent sh*t fuel timing map retard assuming you put 91 ron in your car. the problem is, on your ba+t engine, with a turbo, by the time the ecu has detected knock and pulled timing, your thin rods proberly already bent. 1 Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 9m 2d Posted 08/05/20 12:04 PM Share Posted 08/05/20 12:04 PM Running an external boost controller, or alternatively make it run gate pressure ( which is easy)should keep boost levels super low and might keep it alive. What's b series gate pressure. 3psi or something. 1 Link to comment Share on other sites More sharing options...
Peacefabrications New Member 1 Member For: 3y 9m 16d Posted 07/07/20 07:01 AM Share Posted 07/07/20 07:01 AM Hi, how are you progressing with your build? I'm attempting to do the same, NA to turbo on my 05 terry. Already mounted the front intercooler and piped it under the headlights. Picked up a universal kit, bends and connectors for only $260. Found a stock ba turbo and injectors for $350. Fitted used turbo front brakes for $400. I'm going to weld up a full mandrel 3.5" ss exhaust system. $700 in parts. So exhaust, turbo and piping are all sorted. I bought the stock turbo Map sensor and plug to make up the wiring crossover. Could any of you kind gentlemen please point me in the right direction? Do I need a boost sensor? Because I can't find any existing loom and I'm only going for stock boost. If I buy an xcal x4 or x3, are base turbo tunes available to download somewhere? Has anyone got tips for drilling and tapping the sump? Many thanks Link to comment Share on other sites More sharing options...
