jas98 Member 1,029 Member For: 11y 9m 2d Gender: Male Location: Maryborough Qld Posted 05/05/20 01:47 AM Share Posted 05/05/20 01:47 AM Hi all have had a few issues but came good however yeaterday had battery disconnected on my ba xr6t when went to reconnect all was hood. Started car and idled ok. About 15 seconds later wipers flicked on by themselfs.....seems when starting car nownthry cycle 3 times...... Battery is brand new 3 day old. It did this last time battery was disconnexted aswell but came came good. I fid have to get a part of body of car in boot welded yesterday but seeing this problem was also there last time I doubt it caused any issues (battery diconnected) Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 05/05/20 02:23 AM Share Posted 05/05/20 02:23 AM that's weird AF haha I'd be disconnecting the battery for 30+min then re-connecting it to see if it fixes it. And if it doesn't, I'd be sure it's an electrical issue. Link to comment Share on other sites More sharing options...
jas98 Member 1,029 Member For: 11y 9m 2d Gender: Male Location: Maryborough Qld Posted 05/05/20 04:58 AM Author Share Posted 05/05/20 04:58 AM Haha yeah. So I was at work when wife told me. But now home. Basically start car....no wipers or aftermarket sterio that's getting power from the ACC plug that's located under steering wheel area. Drive along out of nowhere wipers cycle for 3 times and everything turns back on (after wipers cycle) I tried starting just before and no wipers etc. So diconnected battery for 30 seconds and back on and went for drive and alll back to normal....for.now.....so far.... Ford guy told me BCM issue. Auto elec said it sounds very weired but bcm is likely. Another place said nevwr herd it before haha. Maybe did just need a reset? How hard is it to swap BCM in a ba xr6t. Aer there different ones? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 05/05/20 05:42 AM Share Posted 05/05/20 05:42 AM BCM? are they referring to PCM (Powertrain Control Module or another name for an ECU) or BEM (Body Electronics Module) haha... I assume they're referring to the BEM and it's a simple enough job to change it out as it's a separate module/box mounted in the ICC. Link to comment Share on other sites More sharing options...
jas98 Member 1,029 Member For: 11y 9m 2d Gender: Male Location: Maryborough Qld Posted 05/05/20 08:57 AM Author Share Posted 05/05/20 08:57 AM Haha yeah my bad BEM. Been fine since battwry dosconnect. But yeah. Turns out I need 2 keys to get it programed if I put another BEM in...I only.have 1 key ffs lol loterally cheaper for me to buy a ignition barrel with 2 keys to match with transponders (80 bucks all up) then it is to buy 1 key from ford for $180... Do you know if I can use forscan to program it all in myself? Ford said about 210 for them to install BEM and program...drive in drive oit if I supplied it. Another auto electric guy said they send them away to be gixed but need key....key reader and bem and will take up to 3 weeks plus....I <3 Bananas haha Although now everything is workig fine 😂 Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,019 Member For: 9y 3d Gender: Male Location: Canberra ACT Posted 05/05/20 09:25 AM Share Posted 05/05/20 09:25 AM I had a key cut and coded for my BA pretty easily by a locksmith so you might be able to do that so that you have two?Tried Mister Minit the first time - key would go in and start the car, but would not come out again... Link to comment Share on other sites More sharing options...
jas98 Member 1,029 Member For: 11y 9m 2d Gender: Male Location: Maryborough Qld Posted 05/05/20 08:57 PM Author Share Posted 05/05/20 08:57 PM Haha yeah. Locksmith was 150 for key. Mr minit 180. Ford wants 160 just to supplie key. I can get a ignition barrel....lock and 2 keys cut ...all genuine for 80 bucks just need codeing. Looking into useig forscan to do it. Anyone know the best obd11 plig to do ot with? Link to comment Share on other sites More sharing options...
jas98 Member 1,029 Member For: 11y 9m 2d Gender: Male Location: Maryborough Qld Posted 06/05/20 01:27 AM Author Share Posted 06/05/20 01:27 AM Alright. Spoke to another ford guy whos now a parts guy at ford. He said sounds like BEM and by me dosconnecting battery and reconecting it has reset itself. So hopefully its all ot needed as it seems fine now. Either way I will look into forscan and an extr key etc Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 06/05/20 01:31 AM Share Posted 06/05/20 01:31 AM sounds good, mate that 30min reset of the battery fixes a surprising amount of things, especially in FG's. Link to comment Share on other sites More sharing options...
jas98 Member 1,029 Member For: 11y 9m 2d Gender: Male Location: Maryborough Qld Posted 20/08/20 10:03 PM Author Share Posted 20/08/20 10:03 PM Long story short. After a heap of stuffing round and just before I decide to sway the BEM I was checking over car again when it was doing this problem and turns out it was a faulty relay.....alll corroded inside (one cover removed) Fun thing was it was 2 bad relays as when I swapped it from the power window switch one (to fault find) that one aswell was bad. So pulled guess box out and checked all wording and everything seemed ok and been working for a few weeks fine now Link to comment Share on other sites More sharing options...
