mickqueensland New Member 9 Member For: 8y 9m 2d Posted 03/05/20 07:12 AM Share Posted 03/05/20 07:12 AM Hi all, seeking a little advice on my FG Mk2 na. It developed a massive petrol leak from under the car. Obviously it was from the Fuel Filter. When I got under to check it was leaking from fuel hoses that were connecting the fuel filter to the fuel lines. Now, I thought all 4.0 falcons used a fuel filter with nuts that screwed into the fuel line. SO, question, has mine been bodged up some time before I got her? Or did some come from factory like that (I doubt it very much) If it is a bodge job I may take it back to ford and replace the fuel lines and filter with correct parts. Thanks for any help from any one who knows Cheers, Mick Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 1d Gender: Male Location: Perth Posted 03/05/20 07:15 AM Share Posted 03/05/20 07:15 AM Post up a photo Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,238 Member For: 15y 11m 18d Gender: Male Location: Melbourne Posted 03/05/20 07:23 AM Share Posted 03/05/20 07:23 AM all falcons use the same fuel filter from the factory (not sure how far back it goes, but I know for sure BA-FGX do) underneath the car that is indeed connected to two male threads on the fuel filter itself via two female threaded nuts on the fuel line (one each side of the filter). Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 1d Gender: Male Location: Perth Posted 03/05/20 07:30 AM Share Posted 03/05/20 07:30 AM Yes but they get over tightened which flares and galls the nut in the filter. This will be a bodge job for sure 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,238 Member For: 15y 11m 18d Gender: Male Location: Melbourne Posted 03/05/20 07:32 AM Share Posted 03/05/20 07:32 AM yep ^^ that's likely what happened to cause your fuel leak, OP. Link to comment Share on other sites More sharing options...
mickqueensland New Member 9 Member For: 8y 9m 2d Posted 03/05/20 08:13 AM Author Share Posted 03/05/20 08:13 AM Thanks guys, I thought it was a bodge job, most likely due to wrecking the original threads / nuts The filter I removed has 8mm barbs on either end but otherwise looks similar to the stock filter. The fuel hoses were all cracked. Not even EFI hose either. It was like that since I got the XR6 in 2015 when it was 3 years old. I took a pic but have up trying to post it, too hard. cheers Mick Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 1d Gender: Male Location: Perth Posted 03/05/20 08:25 AM Share Posted 03/05/20 08:25 AM Exactly what I though. That filter is fro EA falcon. You can buy the new threaded nut sections from ford. I have changed a few Link to comment Share on other sites More sharing options...
