BJSXR6TMKII Member 30 Member For: 3y 11m 11d Posted 16/04/20 12:02 PM Share Posted 16/04/20 12:02 PM Hey guys, I have a ba xr6t MKII 6 speed manual, I've owned it for 2 years and recently spoke to the first owner of the car who told me it was pushing 16psi when he had it and that he'd put all the goodies into it, walbro fuel pump, 1000cc injectors, valve springs, it also has an upgraded intercooler, when I purchased the car the guy had a boost controller in it and was running 12psi but he removed it before sale and put it back to 5.5-6psi, my question is would I be able to simply buy and connect a new boost controller and pump it back upto 12psi with no hassles or do I need to have it retuned? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,238 Member For: 15y 11m 18d Gender: Male Location: Melbourne Posted 16/04/20 12:30 PM Share Posted 16/04/20 12:30 PM short answer is no, you can't just throw a boost controller in there as it's likely the previous owner also flashed the car back to a factory tune when he removed all of his mods before sale (the previous owner might not have removed the fuel pump or more of the mods, but you'd have to confirm). You'll have to get it tuned to whatever hardware it has in place, especially with fuel flow increase items. 1 Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,013 Member For: 8y 11m 5d Gender: Male Location: Canberra ACT Posted 16/04/20 12:31 PM Share Posted 16/04/20 12:31 PM It has to have had some tuning done if it has aftermarket injectors. There's no need for an aftermarket boost controller on these cars as the factory boost control can do the job in most scenarios. Given it's history, definitely take it to a reputable tuner to at least check AFRs and what injectors and other mods are in it. If that all fine and you want more boost, then get it retuned. Edit: posted at the same time as Keith. In summary, take it somewhere and find out exactly what it's hardware and tune setup is now before you decide what's next. 1 Link to comment Share on other sites More sharing options...
Box stock T. Member 1,384 Member For: 8y 11m 21d Posted 16/04/20 12:59 PM Share Posted 16/04/20 12:59 PM As the lads have said above. It should definitely be looked over by someone who knows these cars. It may be okay, but it also might be a recipe for problems. It has all the goodies just sitting there to be at least running at 315- 330 kw's at 14.5- 15psi safely. Link to comment Share on other sites More sharing options...
BJSXR6TMKII Member 30 Member For: 3y 11m 11d Posted 16/04/20 11:50 PM Author Share Posted 16/04/20 11:50 PM The guy I bought it off had it advertised as 240rwkw so I'd imagine the injectors, fuel pump etc are still there as I would imagine it would be a process to remove it all and replace with standard and he didn't seem to be a bloke that likes doing a great deal to be honest, will a reputable tuner will be able to tell what mods have been done pretty easily? Im happy to have it retuned just want to have it running at its full capability Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,013 Member For: 8y 11m 5d Gender: Male Location: Canberra ACT Posted 17/04/20 12:47 AM Share Posted 17/04/20 12:47 AM Yep definitely. They will be able to look at your existing tune and see the injector data and what is in the boost map. Then a run on the dyno will probably cost $100 or less and tell you whether the fuel system is keeping up with the current boost.It is a good practice with any modified car and plenty of these cars have seen the inside of some pretty average tuning shops, so good to make sure everything is nice and safe for your motor. 1 Link to comment Share on other sites More sharing options...
BJSXR6TMKII Member 30 Member For: 3y 11m 11d Posted 17/04/20 03:57 AM Author Share Posted 17/04/20 03:57 AM Thanks for the replies gents, I've got her booked in to be looked over and find out what's been done and have her tuned, I'll jump back on and share once I've had it looked at, cheers 1 Link to comment Share on other sites More sharing options...
Box stock T. Member 1,384 Member For: 8y 11m 21d Posted 17/04/20 05:25 AM Share Posted 17/04/20 05:25 AM Definitely post up ya dyno sheet results, alot of lads on here can analyze the results. Eitherway you'll be pleasantly surprised if all the mods are still there, it will be back to it's full potential. 1 Link to comment Share on other sites More sharing options...
