Falconhell13 Member 61 Member For: 4y 5m 29d Posted 31/03/20 05:22 AM Share Posted 31/03/20 05:22 AM Can anyone tell me if I csn remoce front springs from a ba xr6t ute with compressors? I have some super lows I want to put in but since nz is on lockdown I cant go buy spring compresors... will I be slgood without them do you think? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 10d Gender: Male Location: Melbourne Posted 31/03/20 05:33 AM Share Posted 31/03/20 05:33 AM are you asking if you can do it without spring compressors? you can remove the struts in one piece at the front (spring and shock) but it's tough to get it out past the control arms etc without the springs being compressed. should still be able to hire them from a hire place... those places should be considered "essential" along with hardware stores etc. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 24d Gender: Male Location: Perth Posted 31/03/20 06:08 AM Share Posted 31/03/20 06:08 AM I have done it many times without compressors, just use rattle gun. It is very dangerous. The new springs being lower will go on easier. If you are smart you can use the cars weight and jacks to do it in the car. Link to comment Share on other sites More sharing options...
Falconhell13 Member 61 Member For: 4y 5m 29d Posted 31/03/20 07:43 AM Author Share Posted 31/03/20 07:43 AM Everywhere here in newzealand are lockdown and they arnt considering any public stuff except food an essential to us at the moment. So im guessing I need to be able to compress the springs to remove the whole strut? Also I dont have a rattle gun but I do have an air ratchet. I have some g clamps but I dont think they will do much good. Will the superlows go in easy enough with me needed to compress then? So im gueesing I could undo the top center nut that holds the spring pressure while using the jack under it to hold the pressure then slowly release the jack done so my springs no longer captive then pull it all out? Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,019 Member For: 8y 11m 29d Gender: Male Location: Canberra ACT Posted 31/03/20 08:06 AM Share Posted 31/03/20 08:06 AM Removing the whole strut (shock and spring assembly) is easy without compressors.Be very very careful if doing the job without spring compressors - people have killed themselves trying.I found with new Kings BA springs, I couldn't compress them enough with spring compressors to install back onto the shock, so had to go to a shop. They said they sometimes break their wall mounted compressors doing it.If you try without spring compressors, you need to be ok with the risk you won't be able to get them back in afterwards.Can you order compressors online? Link to comment Share on other sites More sharing options...
Falconhell13 Member 61 Member For: 4y 5m 29d Posted 31/03/20 08:32 AM Author Share Posted 31/03/20 08:32 AM Aw sh*t that's a worry cause mine are king springs, second hand ones though and I think super low not just low but I really want to be able to get them back in. As far as I know only essential service deliveries are taking place. I thought that I would completely wrap the strut up in a think drop cloth laying on the ground and undo it with a air ratchet Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,019 Member For: 8y 11m 29d Gender: Male Location: Canberra ACT Posted 31/03/20 10:45 AM Share Posted 31/03/20 10:45 AM Yeah mine were low, not super low. But new springs are stiffer than old springs.With super low you might have more chance of using the car and a jack to re-assemble in the car, but yeah car is not drivable for the foreseeable future if it doesn't work. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 10d Gender: Male Location: Melbourne Posted 31/03/20 10:50 AM Share Posted 31/03/20 10:50 AM sounds like it'll be better for you to just wait to lower your car until you're back out of this lockdown haha Link to comment Share on other sites More sharing options...
Falconhell13 Member 61 Member For: 4y 5m 29d Posted 31/03/20 11:18 AM Author Share Posted 31/03/20 11:18 AM You two both talk alot of sense but common sense I do not have, so im going to risk this once and hope for the best. Will keep you guys updated as to how much I fcyk this up Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 10y 2m 8d Gender: Male Location: SW Sydney Posted 31/03/20 09:54 PM Share Posted 31/03/20 09:54 PM Set up the go pro 👌 2 1 Link to comment Share on other sites More sharing options...
