ALADE New Member 11 Member For: 4y 2m 28d Posted 24/03/20 02:50 AM Share Posted 24/03/20 02:50 AM Sorry if this has been here before I want to know if anyone has had there alloys cut and widened , I have the FG limited edition ute and I think the factory wheels look great , so I would like to keep them , but of course I want to go wider on the back something like a 285 or 95 Has anyone here had this done Thanks Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 10y 2m 11d Gender: Male Location: SW Sydney Posted 24/03/20 03:36 AM Share Posted 24/03/20 03:36 AM There's guys out there that do this but way better use of your coin to change rims imho. Not only that, all widening is done to the inside, whereas FG utes are begging for a lower offset, factory offset / wheels are tucked ridiculously far inside the guard 2 Link to comment Share on other sites More sharing options...
ALADE New Member 11 Member For: 4y 2m 28d Posted 24/03/20 06:39 PM Author Share Posted 24/03/20 06:39 PM Yeh I think you’re right mate , buying new wheels is going to be the best option so if I go to 20 inch what’s the best set up for the Ute what set up are you running, I obviously don’t want Tyres scrubbing, a set up that fills the guards would be good thanks Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 10y 2m 11d Gender: Male Location: SW Sydney Posted 24/03/20 10:08 PM Share Posted 24/03/20 10:08 PM I'm running 19x10.5 +22 with 285/30/19 on the rear, compared to factory 17x8 +38 (iirc) this which bumps the wheel outer edge 48mm according to willtheyfit.com https://www.willtheyfit.com/index.php?width=245&aspect=45&diameter=17&wheelwidth=8&offset=38&width2=285&aspect2=30&wheel_size=19&wheel_width=10-5&offset2=22 See posts with pics below, as mentioned in one of them I took a grinder to the guard inner edge return as there would've been 10mm interference otherwise. Based on that just for reference, you should be able to get away with a) 20x10.5 +35~40 or b) 20x9.5 +25~30 without interference but best do your measurements first and compare on willtheyfit.com 1 Link to comment Share on other sites More sharing options...
