G6EEEETTTT Member 27 Member For: 5y 7m 7d Posted 02/03/20 11:10 PM Share Posted 02/03/20 11:10 PM How much power can the factory FG fuel pump handle, before it will need to be replaced with a bigger pump? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,238 Member For: 15y 11m 18d Gender: Male Location: Melbourne Posted 03/03/20 12:39 AM Share Posted 03/03/20 12:39 AM You'll want to be upgrading it if you're going over 300rwkw, ideally even sooner than that... so basically any power mods require a fuel pump. Luckily it's a cheap upgrade. Link to comment Share on other sites More sharing options...
G6EEEETTTT Member 27 Member For: 5y 7m 7d Posted 03/03/20 12:59 AM Author Share Posted 03/03/20 12:59 AM What is the next step up from stock. A Walbro 460? I've heard it needs a wiring upgrade and a new fuel reg? Mine will never see more than maybe 380rwkw on 98. Will a 460 handle that? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,238 Member For: 15y 11m 18d Gender: Male Location: Melbourne Posted 03/03/20 01:07 AM Share Posted 03/03/20 01:07 AM 460 is about as big as a lift pump you'll need, as anything it can't do will need a surge tank. You probably don't need something as big as a 460 if your ultimate goal is 380rwkw. Ask your tuner which fuel pump is a good choice for that level, as they might be able to get you one sorted pretty simply for less than a 460. 1 Link to comment Share on other sites More sharing options...
G6EEEETTTT Member 27 Member For: 5y 7m 7d Posted 04/11/20 09:41 AM Author Share Posted 04/11/20 09:41 AM So coming back to this now. Car now has process west stage 1 intercooler, turbo side intake and x-force 3.5 inch cat back. Wanting to fit injectors, cat pipe and tune. The melbourne tuner I have spoken to says it won’t need a fuel pump upgrade. But surely this is enough to push 300? I was thinking of fitting a walbro 255 like this one myself, prior to the tune, for insurance. Will I be able to fit the pump and drive it for a few days on the stock tune? And is this a good unit to fit? https://www.ebay.com.au/itm/WALBRO-GSS341-255LPH-FUEL-PUMP-ASSEMBLY-FALCON-FG-FGX-XR6-TURBO-XR8-F6-TYPHOON/282621506840?_trkparms=aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20191002094254%26meid%3D234c25a87b1043d48a9cb3f840e299a6%26pid%3D100889%26rk%3D2%26rkt%3D6%26sd%3D292263521702%26itm%3D282621506840%26pmt%3D0%26noa%3D1%26pg%3D2332490%26algv%3DDefaultOrganic%26brand%3DWalbro&_trksid=p2332490.c100889.m5204 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,238 Member For: 15y 11m 18d Gender: Male Location: Melbourne Posted 04/11/20 09:52 AM Share Posted 04/11/20 09:52 AM Yes that pump will be a reasonable upgrade but realistically not 100% necessary for 300 in an FG as your tuner suggests. Do whatever makes you most comfortable. 1 Link to comment Share on other sites More sharing options...
G6EEEETTTT Member 27 Member For: 5y 7m 7d Posted 05/11/20 02:45 AM Author Share Posted 05/11/20 02:45 AM With the mods I listed how much power could it make? I suppose valve springs might come into play possibly as well. I think I might just fit the fuel pump anyway. I might upgrade the turbo and push it up aound 380 rwkw some day so this pump should be able to handle that. Will it be ok to drive with the 255 pump without a tune? I'm assuming the stock fuel reg will be able to keep fuel pressure to where it needs to be, and the afr's will be fine? At least to be able to drive the car to the tuner. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,238 Member For: 15y 11m 18d Gender: Male Location: Melbourne Posted 05/11/20 02:48 AM Share Posted 05/11/20 02:48 AM you've got a G6ET, based on your username, so you're limited to around 320rwkw (on 98) with the stock turbocharger. Yes it's fine to fit the fuel pump without a tune but don't hammer your car on the way to the tuners, just stay off boost whatever mods you put in before going. Stock reg will handle it, yes, but your tuner might prefer it to be upgraded down the track. 1 Link to comment Share on other sites More sharing options...
G6EEEETTTT Member 27 Member For: 5y 7m 7d Posted 05/11/20 02:52 AM Author Share Posted 05/11/20 02:52 AM Thanks. Yeah I wouldn't hammer it before it got to the tuner. Link to comment Share on other sites More sharing options...
