El Andrew Gold Donating Members 2,019 Member For: 9y 1d Gender: Male Location: Canberra ACT Posted 24/02/20 11:19 AM Author Share Posted 24/02/20 11:19 AM Ah yes of course, I was getting confused with connecting the compressor cover directly to the wastegate.Hmmmm so I guess I'm maybe looking at either an exhaust issue or a boost leak.I've swapped the factory BOV valve in for the drive to work tomorrow - probably done enough driving around the neighbourhood like a knob for one night. 1 Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,019 Member For: 9y 1d Gender: Male Location: Canberra ACT Posted 26/02/20 10:29 AM Author Share Posted 26/02/20 10:29 AM No change with factory BOV so wasn't that. Rechecked for loose intercooler pipes and everything is perfect.Removed the cat and I can see through it, so it isn't that so am a bit stumped.Could it be a collapsed muffler? Have always thought the exhaust sounds pretty spluttery.Might investigate if the wastegate is stuck open too. I've got a good exhaust guy so will have a chat to him too. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,300 Member For: 16y 13d Gender: Male Location: Melbourne Posted 26/02/20 01:23 PM Share Posted 26/02/20 01:23 PM when you're looking through the cat, does it look like a honeycomb/lattice all the way through? or does it look like a big open space? Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,019 Member For: 9y 1d Gender: Male Location: Canberra ACT Posted 26/02/20 09:20 PM Author Share Posted 26/02/20 09:20 PM Honeycomb whole way through. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,300 Member For: 16y 13d Gender: Male Location: Melbourne Posted 27/02/20 12:36 AM Share Posted 27/02/20 12:36 AM well then it isn't your cat being collapsed. 1 Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,019 Member For: 9y 1d Gender: Male Location: Canberra ACT Posted 27/02/20 10:34 AM Author Share Posted 27/02/20 10:34 AM Just thought to check the air filter. Was pretty filthy which I'm putting down to the weeks of smoke we had here. Only cleaned it 5k ago. Had a new Ryco paper filter lying around so chucked it in.Didn't make a difference.Did happen to be on a private road where I got stuck at a series of red lights, so could do some decent pulls. Will spike to10 psi and then drop as the revs rise. Exhaust actually sounded quite bad - not sure if that is the issue or just a symptom so will definitely get that checked next. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,300 Member For: 16y 13d Gender: Male Location: Melbourne Posted 27/02/20 10:46 AM Share Posted 27/02/20 10:46 AM interesting situation... 10psi sounds about right for a stock FG XR6T? Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,019 Member For: 9y 1d Gender: Male Location: Canberra ACT Posted 27/02/20 10:51 AM Author Share Posted 27/02/20 10:51 AM Yeah but it won't hold it for more than a second and is tuned for 14 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,300 Member For: 16y 13d Gender: Male Location: Melbourne Posted 27/02/20 11:24 AM Share Posted 27/02/20 11:24 AM does still sound like a boost leak, then... e.g. it's sealing pretty well until the 9-10psi mark then it blows the opening open a little more and most of your boost leaks out as you go into higher revs. Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,019 Member For: 9y 1d Gender: Male Location: Canberra ACT Posted 04/03/20 06:25 AM Author Share Posted 04/03/20 06:25 AM Went to the exhaust shop today and exhaust is fine. Couldn't find any other issues with the car and thinks there is a good chance the wastegate is cracked. Not sure if that means the flap or the turbine housing around it.Is going back next week so he can pull the dump off and have a look. Link to comment Share on other sites More sharing options...
