blacktur8oute Member 139 Member For: 10y 3m 27d Gender: Male Posted 06/02/20 03:54 AM Share Posted 06/02/20 03:54 AM Hi all ive just purchased a gen2 supercore for my FG whats the best way to go about the rear housing do I just use the original with the flapper mod should I external gate it and mount it to the original manifold or do I put it on a 6 boost also what size housing works best with these, want to do it once properly cheers Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,238 Member For: 15y 11m 18d Gender: Male Location: Melbourne Posted 06/02/20 03:59 AM Share Posted 06/02/20 03:59 AM depends on your boost level and power goals, realistically... that being said; the stock housing with a decent port and flapper mod will do the job for most applications Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 9m 26d Gender: Male Location: Adelaide Posted 06/02/20 05:31 AM Share Posted 06/02/20 05:31 AM Factory 1.06 rear housing is the right size but your port job needs to be bang on perfect otherwise you’ll be up high in the boost range even with a tune. Actuator preload is critical to get right too if in doubt get the tune shop to fit it and port & flapper it if you’re dead set on doing it yourself I sell monster port new housings and actuators and will walk you through the set up process 2 Link to comment Share on other sites More sharing options...
blacktur8oute Member 139 Member For: 10y 3m 27d Gender: Male Posted 06/02/20 10:33 AM Author Share Posted 06/02/20 10:33 AM I’ll PM you Jet Link to comment Share on other sites More sharing options...
