Gh0stk1ll3r Member 25 Member For: 5y 3m 1d Posted 03/02/20 09:14 AM Share Posted 03/02/20 09:14 AM Hi everyone. I'm one more ETC light and throttle cutting limp mode away from burning my car to the ground. A year-ish ago some of you may remember me searching for help to get my BA XR6T engine running in my blown up BF XR6 on its NA PCM. Fast forward to today and I'm loving the car, except for when I try to overtake or have a little fun. In any gear (Auto) you can not rev past 50% throttle travel. In Park it revs to the floor no issues. It was suggested that my ABS sensors may be dirty, they were indeed dirty, but weren't the problem. I've since tried a different TPS, different Throttle Body and checked the entirety of the engine for vacuum leaks or the such, no dice. I'm throwing one code P0420, which stumps me because as far as I know that's a BF code, and I've got a BA tune. Has anyone else had this issue? I've found similar ones but none trigger like mine do. Could no boost refernce in the PCM cause this? My tuner left the factory boost control in the tune, and due to the problem im having I've not yet been able to road tune my GFB Boost Contoller. My boost gauge has never read higher than 4.5 PSI and cuts at any boost level. I did notice my AFR gauge reads around 10.00 before it cuts. Rich? I appologise for the barrage of questions. Thanks legends. Link to comment Share on other sites More sharing options...
BeerTurbo Donating Members 234 Member For: 5y 11m 14d Posted 14/02/20 06:27 AM Share Posted 14/02/20 06:27 AM code P0420 do you have single 02 sensor like the BA spec or twin 02 sensors like the Bf spec? if your using a BF ecm I would make sure your secondary 02 sensor is turned of correctly https://forum.pcmtec.com/topic/547-removing-rear-o2-sensor/?tab=comments#comment-3085 AFR in the 10 is indeed verry rich, if you want to play along with 02 sensors issue then you can look further into the enrichment the ford ecm will do when it thinks the cat converter is to hot.. obviously works this out based on the 2 02 sensors (up and downstream of the cat). https://forum.pcmtec.com/topic/237-howto-engine-protection-settings/?tab=comments#comment-1544 Fuel enrichment on catalytic converter over temperature Fuel enrichment on exhaust over temperature Fuel enrichment on turbo over temperature Otherwise - are your injectors leaking? A boost level of 4.5psi is not enough to induce torque reduction on factory b series boost map. are you sure its cutting and not just misfiring from over-fueling, due to your potential bad 02 sensors programming or hardware? Link to comment Share on other sites More sharing options...
Gh0stk1ll3r Member 25 Member For: 5y 3m 1d Posted 19/02/20 03:13 PM Author Share Posted 19/02/20 03:13 PM Hi mate, thanks for the reply. Just had the PCM retuned, still having the issue but I'm throwing a different code now. P1131 I have an idea, I was checking my PCV valve vacuum line routing today and noticed my line doesn't have a Check Valve in it. Could this be the source of my issue? Boost pressure in the rocker cover? Thanks Link to comment Share on other sites More sharing options...
rollex Member 682 Member For: 9y 10m 15d Gender: Male Location: Australia Posted 28/02/20 01:16 PM Share Posted 28/02/20 01:16 PM Throw the gfb boost controller in the bin and put the stock controller back. All aftermarket systems go backwards over stock. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,300 Member For: 16y 13d Gender: Male Location: Melbourne Posted 28/02/20 02:01 PM Share Posted 28/02/20 02:01 PM but not your tuning bits, of course... Link to comment Share on other sites More sharing options...
rollex Member 682 Member For: 9y 10m 15d Gender: Male Location: Australia Posted 29/02/20 07:36 AM Share Posted 29/02/20 07:36 AM Ours aren't aftermarket. The stock boost control is excellent and doesn't need changing. Link to comment Share on other sites More sharing options...
Gh0stk1ll3r Member 25 Member For: 5y 3m 1d Posted 29/02/20 07:51 AM Author Share Posted 29/02/20 07:51 AM I'm using the GFB Gforce 3 for a reason, I've got an N/A loom so no factory boost control. Anyway all that aside I fixed it this weekend. I found my fuel system wasn't going into Closed Loop as it should and my O2 sensor voltage was static. New O2 sensor and I was getting into Closed Loop but it'd still jump back into Open Loop Fault and run obscenely rich. Pulled my reg and found the filter destroyed threw in a new one and now I'm good as gold. 1 Link to comment Share on other sites More sharing options...
