BA_COON New Member 2 Member For: 4y 1m 27d Posted 01/02/20 07:08 AM Share Posted 01/02/20 07:08 AM Ok, so I got a 04 BA, column shift.. It will overheat on hot days or under load, say a steep hill, giving it a quick boot on a hot day will send temp guage on a hige hike into the reds.. pull over and thermostat will cool it down eventually. I replaced the termostat today, its normal operating temp is on half way .. which apparently their thermostats open at 89-93 celsius .. so its already running hotter then it should even on a cold day .. collant is bright green, no rusty colour, no coolant leaks anywhere.. could a mechanical issue cause overheating? Idk which way to tackle this thing .. help? Please and thanks. Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 8m 7d Posted 01/02/20 07:47 AM Share Posted 01/02/20 07:47 AM Do your fans come on?Water pump? Link to comment Share on other sites More sharing options...
BA_COON New Member 2 Member For: 4y 1m 27d Posted 01/02/20 07:48 AM Author Share Posted 01/02/20 07:48 AM Yea fans come on, they have both their speeds completely on time, water pump has no visual leaks, seems to have pressure too .. but I havent pulled it off the check it out .. Link to comment Share on other sites More sharing options...
Brad82 New Member 9 Member For: 4y 10m 18d Posted 05/06/20 10:07 AM Share Posted 05/06/20 10:07 AM Any chance there's some air in the system? Run the car for a few minutes with the radiator cap off. Link to comment Share on other sites More sharing options...
