Bulletime Donating Members 937 Member For: 13y 2m 20d Gender: Male Posted 01/02/20 01:25 AM Share Posted 01/02/20 01:25 AM I can do multiple laps of eastern creek with 250kmh, 200 and 170 kmh stops each lap with no fade. Engine overheats but hopefully working on that. 6 pot brembos up front dba t3, always fresh high temp brake fluid, braided lines and winmax circuit pads. Brake ducting from ppl who have done it is a massive pita, I would make sure everything else is tip top, u could remove fog lights and the lower parts of the inner guard IF everything else doesnt help. Link to comment Share on other sites More sharing options...
Slowxr6t Member 512 Member For: 5y 3m 25d Location: New zealand Posted 09/02/21 04:43 AM Share Posted 09/02/21 04:43 AM Hi Guys, I'm looking at brembo 4 pot calipers and 355mm dba rotors for the front of my fgx. I have found 2 sets of brembo calipers on trade me here in NZ, hoping someone can tell me if I can get them to fit. The first set model numbers are 20.8653.01 1A and 20.8534.01 1A the bolt centre spacings are 13.5 cm. The second set model numbers are 20.8534.01 1A and 20.8535.03 1A 05 the bolt spacings are 14.8cm. are these the right ones and will I have to go to ford to order adapter brackets? I'm trying to do this cheaper than just buying a full genuine set off ford and spending squillions of $. Any help is appreciated, thanks. Link to comment Share on other sites More sharing options...
Slowxr6t Member 512 Member For: 5y 3m 25d Location: New zealand Posted 09/02/21 06:27 AM Share Posted 09/02/21 06:27 AM @JETURBO maybe you could shed some knowledge on my queries above, thanks Link to comment Share on other sites More sharing options...
joncitizen Member 91 Member For: 12y 6m 26d Posted 09/02/21 10:33 AM Share Posted 09/02/21 10:33 AM I don't think you will get brackets separately. Googling those parts number looks like they're of a range rover or similar with an integrated bracket part of the casting. The falcons use an adapter to the knuckle that screws into the caliper, the caliper cast has no mountings integrated. Link to comment Share on other sites More sharing options...
Slowxr6t Member 512 Member For: 5y 3m 25d Location: New zealand Posted 11/02/21 06:50 AM Share Posted 11/02/21 06:50 AM Hey thanks @joncitizen it looks like there's not much way to cheap out to do this. I will need to hunt for a genuine ford set of brembo 4 pots for the front. Is there any advantage or disadvantage going to front 6 pots? Link to comment Share on other sites More sharing options...
joncitizen Member 91 Member For: 12y 6m 26d Posted 11/02/21 09:25 AM Share Posted 11/02/21 09:25 AM (edited) Maybe see what your local friendly NZ ford dealer can do them for, here they are a trade club special with everyone like MR. FPV, Intune Motorsport and Mackielec Industries all reselling them. I have had 6 pots and 4 pot fronts on the same car, and I haven't found any difference tbh. Here is a comparison between the two. (BA/BF) but same idea: The 6pots look a million times better though. Edited 11/02/21 09:27 AM by joncitizen yeahnahyeah Link to comment Share on other sites More sharing options...
Slowxr6t Member 512 Member For: 5y 3m 25d Location: New zealand Posted 11/02/21 09:31 AM Share Posted 11/02/21 09:31 AM @joncitizenthanks for that, does the 6 pot have a bigger pad? Link to comment Share on other sites More sharing options...
Bulletime Donating Members 937 Member For: 13y 2m 20d Gender: Male Posted 11/02/21 09:14 PM Share Posted 11/02/21 09:14 PM 6 pots are a bigger pad and better heat dissipation with it being spread out more over the rotor. Theres also better clamping force from the extra pistons. If u track or want to seriously track your car 6 pots, otherwise on the street you probably wont notice the difference much beyond the look lol Buy what you can afford ultimately. Link to comment Share on other sites More sharing options...
Slowxr6t Member 512 Member For: 5y 3m 25d Location: New zealand Posted 14/02/21 10:34 PM Share Posted 14/02/21 10:34 PM Hi guys, so I was told that no xr6 turbo stock wheels can fit brembo 6 pots even 19s on the fgx. I will need fpv wheels. Is this true?? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,239 Member For: 15y 11m 19d Gender: Male Location: Melbourne Posted 15/02/21 12:18 AM Share Posted 15/02/21 12:18 AM All FPV wheels clear, some non-FPV wheels foul. Best to test-fit where possible. Link to comment Share on other sites More sharing options...
