Jord460 New Member 5 Member For: 4y 2m 23d Posted 05/01/20 03:11 AM Share Posted 05/01/20 03:11 AM Hi im new to this forum and I'm sorry if this has been covered before I've just bought a Ba xr6 5 speed manual its had a lot work done bigger brakes front and rear, bigger swaybar twin exhaust kpm tuned but I want more power only paid 1900 for the car with a blown clutch and gearbox I put out of turbo I'm only wanting 250rwkw because of t5 my main question it can the na ecu retain a turbo tune or do you have to use the turbo ecu as that also has boost control Cheers Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,238 Member For: 15y 11m 18d Gender: Male Location: Melbourne Posted 05/01/20 03:17 AM Share Posted 05/01/20 03:17 AM the N/A PCM doesn't have the plug for the wiring loom that supports electronic boost control and an N/A car doesn't have the wiring loom endpoints to go from the PCM to the boost control bits and pieces. you can either get a Turbo PCM (and associated extra loom) trained to your car by an expert in these things and then get it dyno tuned properly or you can get a separate boost controller and then tune the N/A PCM alongside it (extra work for the tuner). Link to comment Share on other sites More sharing options...
Jord460 New Member 5 Member For: 4y 2m 23d Posted 05/01/20 03:26 AM Author Share Posted 05/01/20 03:26 AM I think I might just get the turbo ecu and looms to suit and get it coded in I think that's going to be better Thanks you for the reply Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,238 Member For: 15y 11m 18d Gender: Male Location: Melbourne Posted 05/01/20 03:33 AM Share Posted 05/01/20 03:33 AM if you're doing a full N/A to turbo conversion, there's a lot more involved than just that, though... have a read of the N/A forum's sticky topics about the conversion (here) and see what else you need to do to get the job done. Link to comment Share on other sites More sharing options...
Jord460 New Member 5 Member For: 4y 2m 23d Posted 05/01/20 04:33 AM Author Share Posted 05/01/20 04:33 AM ive got all the parts there manifold intercooler turbo pipeing exhaust etc just too many conflicting reports about what ecu you can use Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,238 Member For: 15y 11m 18d Gender: Male Location: Melbourne Posted 05/01/20 04:36 AM Share Posted 05/01/20 04:36 AM right... good luck with it, then... keep us updated with how you get on. just to let you know, though, it's never financially worth it to keep an N/A and turbo it, as compared to selling up the N/A and buying a turbo Link to comment Share on other sites More sharing options...
Quincy Oconnor New Member 6 Member For: 4y 1m 21d Posted 21/05/20 06:16 AM Share Posted 21/05/20 06:16 AM you can run a boost T and retain the stock ecu. and go get a map sensor off a maxda cx7 turbo (cheaper than a fg turbo but exact same part number) and it plugs right into the stock ba loom. Link to comment Share on other sites More sharing options...
