BoostedG6E Member 105 Member For: 6y Gender: Male Location: Melbourne Posted 28/12/19 04:13 AM Author Share Posted 28/12/19 04:13 AM I think you've got it mate, because each time its melted, the connection has been lose, I was never sure weather it came lose first or once it was already melted but I think potentially its come lose and caused it to draw more power then melted and cause there is no fuse on the power wire it has just melted the cradle. That double nut fittings looks like a winner where did you see that one ? Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 27d Gender: Male Location: Perth Posted 28/12/19 05:43 AM Share Posted 28/12/19 05:43 AM Just a google search. I thinks its from a race tank. Link to comment Share on other sites More sharing options...
BoostedG6E Member 105 Member For: 6y Gender: Male Location: Melbourne Posted 28/12/19 05:45 AM Author Share Posted 28/12/19 05:45 AM Thanks heaps for you help mate really appreciate it Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 27d Gender: Male Location: Perth Posted 28/12/19 05:50 AM Share Posted 28/12/19 05:50 AM (edited) Found them. http://www.radiumauto.com/Electrical-Bulkhead-Stud-Kit-6-Pack-P1049.aspx "I think you've got it mate, because each time its melted, the connection has been lose, I was never sure weather it came lose first or once it was already melted but I think potentially its come lose and caused it to draw more power then melted and cause there is no fuse on the power wire it has just melted the cradle" that's why I get paid the BIG bucks. Edited 28/12/19 05:52 AM by arronm Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 7m Gender: Male Location: Perth Posted 04/01/20 02:38 PM Share Posted 04/01/20 02:38 PM At the risk of pointing out the obvious you don't need insulated bulkhead connectors to go through a thermoplastic Pump Module. Double R Ron is the metallologist and will be able to explain why zinc/nickel coated studs/bolts won't be the best conductors (something about surface conduction or something vs a whole conductors) but if I was you I'd get some good old black steel m6 bolts and nuts, install quality crimps and use the black steel bolts to secure them. I use https://www.efihardware.com/products/1593/submersible-pump-bulk-head-terminals to run my TWIN intank 460's but had changed to black steel bolts purely due to the thickness of my fuel tank hat. Buy Aussie Bro lol thickness. Link to comment Share on other sites More sharing options...
NA_TURBO Member 532 Member For: 8y 6m 15d Gender: Male Location: Mildura Posted 18/12/20 11:04 AM Share Posted 18/12/20 11:04 AM I'm trying to do the same thing using the bulk head fittings but one set melted through and the new ones are getting red hot..Any tips please Ralph? Link to comment Share on other sites More sharing options...
BoostedG6E Member 105 Member For: 6y Gender: Male Location: Melbourne Posted 18/12/20 11:21 PM Author Share Posted 18/12/20 11:21 PM Hey mate, this was probably one of the biggest I <3 Bananas arounds to date with my car. I melted my cradle 4 times trying to figure it out. I eventually gave up got a new cradle and ran power and earth straight into the standard plug I get good volts at the pump and have since had zero issues. Regarding the issue for the bulk heads though, I did find that it was always coming lose and drawing more, you need to make sure you are drilling the perfect size hole to let the inner seal from the bulkhead drop in and seal. At times it was not lose from the top, but once I pulled the cradle I noticed it had come lose from the bottom. If I could go back I would have done what I done now but after the first cradle. Link to comment Share on other sites More sharing options...
NA_TURBO Member 532 Member For: 8y 6m 15d Gender: Male Location: Mildura Posted 19/12/20 12:51 AM Share Posted 19/12/20 12:51 AM Thanks mate, I just went up to work and got another module so I'll run the power through the factory plug like you said. Think I'm going to just get the AI intank surge setup Link to comment Share on other sites More sharing options...
