violetpop Silver Donating Members 436 Member For: 4y 3m 21d Posted 04/04/21 10:28 AM Author Share Posted 04/04/21 10:28 AM Yeah I saw the fenix rad, looks like a nice bit. Was wondering about clearance issues. Will probably end up with a stock 32mm replacement at this stage. 3 hours ago, adams355 said: 400rwkw will spin up easily in second. Was the dyno sheet from its actual last run on the dyno. I'd say that's when the problem started and we all know how bike riders like to limiter bash all the time . You might have been down on power when you picked it up and just got worse over time. Is it pinging, have you got a boost gauge on it? It says run #18 on the sheet. It feels the fastest its ever been. When I picked it up, it would dance on the tyres when getting on it but this is full blown wheel spin and then the hose pops off. I've got 2, pillar mounted and through the torque app. Highest registered was 16psi but again not accurate as the hose comes off. I didn't have a single issue with the hose since fitting it the way jet suggested and about 3 months driving since the tune. I will have to sort the rad out and look at it again. No ping detected. 1 Link to comment Share on other sites More sharing options...
NA_TURBO Member 532 Member For: 8y 5m 21d Gender: Male Location: Mildura Posted 04/04/21 10:35 AM Share Posted 04/04/21 10:35 AM Yeah I saw the fenix rad, looks like a nice bit. Was wondering about clearance issues. Will probably end up with a stock 32mm replacement at this stage. It fits just fine, I've got mine sitting in the engine bay but I can trial fit the fans and let you know? I was going to change balancer before I fitted the radiator but happy to test fit if you're curious? 1 Link to comment Share on other sites More sharing options...
violetpop Silver Donating Members 436 Member For: 4y 3m 21d Posted 04/04/21 10:37 AM Author Share Posted 04/04/21 10:37 AM Don't go out of your way mate all good. I feel like for what I'll be doing with the car, the stock will be fine Link to comment Share on other sites More sharing options...
NA_TURBO Member 532 Member For: 8y 5m 21d Gender: Male Location: Mildura Posted 04/04/21 10:42 AM Share Posted 04/04/21 10:42 AM If you need me to test it just let me know, I'm a long way off reassembly haha. You'll probably pay somewhere between $250-$350 for a stock radiator, that's why I went with the Fenix one. It's worth the investment 1 Link to comment Share on other sites More sharing options...
adams355 Member 529 Member For: 6y 10m 28d Gender: Male Location: Brisbane Posted 04/04/21 10:44 AM Share Posted 04/04/21 10:44 AM 10 minutes ago, violetpop said: 22 minutes ago, adams355 said: 400rwkw will spin up easily in second. Was the dyno sheet from its actual last run on the dyno. I'd say that's when the problem started and we all know how bike riders like to limiter bash all the time . You might have been down on power when you picked it up and just got worse over time. Is it pinging, have you got a boost gauge on it? It says run #18 on the sheet. It feels the fastest its ever been. When I picked it up, it would dance on the tyres when getting on it but this is full blown wheel spin and then the hose pops off. I've got 2, pillar mounted and through the torque app. Highest registered was 16psi but again not accurate as the hose comes off. I didn't have a single issue with the hose since fitting it the way jet suggested and about 3 months driving since the tune. I will have to sort the rad out and look at it again. No ping detected. Yea I'm not blaming the tuner at all just it might have started the issue on a minor level at that time. Yea 16 on torque app is fine, it can be up to 2-3psi high unless you change some of the settings when you have a proper gauge on it or on the dyno. Jut keep an eye on it I guess. 2 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,045 Member For: 9y 2m Gender: Male Location: South Australia Posted 04/04/21 10:46 AM Share Posted 04/04/21 10:46 AM Maybe your spark plugs/cam timing/coils are/is working properly now? It's amazing what a set of plugs will do. Maybe you fixed a boost leak? 3 Link to comment Share on other sites More sharing options...
violetpop Silver Donating Members 436 Member For: 4y 3m 21d Posted 04/04/21 10:54 AM Author Share Posted 04/04/21 10:54 AM Entirely possible Puff. Fresh plugs and gap set yes, Didnt see anything extremely obvious but the inlet manifold bolts were not as tight as what I did them up to when I put the engine in probably that crappy gasket settling in. Will monitor when things get moving again and I can get this hose to stay on. Link to comment Share on other sites More sharing options...
violetpop Silver Donating Members 436 Member For: 4y 3m 21d Posted 06/04/21 10:12 AM Author Share Posted 06/04/21 10:12 AM Picked up a radiator 32mm variation, fresh hoses and the coolant bottle. The black one was giving me the sh*ts. Just about to head out and see how it goes. 3 Link to comment Share on other sites More sharing options...
violetpop Silver Donating Members 436 Member For: 4y 3m 21d Posted 06/04/21 11:38 AM Author Share Posted 06/04/21 11:38 AM Well the cooling side of things are spot on now but the car sure is over boosting. Foot down 3rd gear and I got out of it straight away. The way the boost came on so quick and strong I backed off immediately. Look down over 20psi then look back to see my rods on the road, nothing luckily.Pulled up at the servo and bypassed the boost solenoid and run it on spring pressure and it kept solid on just under 16.Something has happened and I can't exactly figure out why.. Possibly the engine was hurt right from buying it from the wrecker or as puff mentioned that I fixed something. Either way some dyno time will be in order to correct the issue and this will be the perfect time to lower the boost down to 12 psi or so.For now I plan leave the solenoid disconnected. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,240 Member For: 15y 11m 19d Gender: Male Location: Melbourne Posted 06/04/21 11:44 AM Share Posted 06/04/21 11:44 AM if you've bypassed the solenoid and you're making 16psi you won't be able to go under 16psi without changing the actuator or it's pre-load settings. 2 Link to comment Share on other sites More sharing options...
