eff xr6t Member 569 Member For: 10y 5m 28d Posted 21/12/20 10:07 AM Share Posted 21/12/20 10:07 AM At this stage I am planning to not pull the head off or get the pistons out but probably have a look at some of the engine bearings and try get an idea of the kind of life the engine has had. Dont undo the rod bolts dont even check the bearings. You will do more damage undoing and retorquing the torque to yeild rod bolts then looking at the bearings that will be fine anyway.On the subject of valve springs I tested a bunch on my spring tester the results didnt suprise me much. 06/06 bf turbo/typhoon springs 75lb on the seat. Fg N/a 75lb on the seat. Second hand $20 atomic set I got of some dude that replaced them 105lb on the seat. 1 Link to comment Share on other sites More sharing options...
violetpop Silver Donating Members 436 Member For: 4y 3m 21d Posted 21/12/20 10:40 AM Author Share Posted 21/12/20 10:40 AM I think at minimum I should get the windage tray off to get a better look at the rod number then focus on the rest. If I need to run less boost I'll need to change the spring in the actuator. Link to comment Share on other sites More sharing options...
violetpop Silver Donating Members 436 Member For: 4y 3m 21d Posted 22/12/20 08:37 AM Author Share Posted 22/12/20 08:37 AM So good news, I was able to confirm the rod part number starts with a 3! Using a light and mirror and a very specific angle I could see it. What a relief!Moving forward now I managed to strip all the crap off the engine and give it a bit of a wash down.I've got a rocker cover gasket kit coming as its leaking from every seal. Pretty much ready for pump gears and springs to go in now. 1 Link to comment Share on other sites More sharing options...
adamjoe New Member 3 Member For: 3y 3m 7d Posted 22/12/20 08:59 AM Share Posted 22/12/20 08:59 AM (edited) The spray ceramic coating moderator's note: is a waste of money... item is an expert coating item with hydrophobic impacts. This item likewise utilizes a blend of both SIO2 and TIO2 to offer extreme security from dust, water, daylight, extraordinary climate, grime, and other hurtful ecological components. You can likewise utilize this item to improve the exhibition and life span of your current sealant. Edited 22/12/20 10:56 PM by k31th commercial posting Link to comment Share on other sites More sharing options...
violetpop Silver Donating Members 436 Member For: 4y 3m 21d Posted 22/12/20 10:14 AM Author Share Posted 22/12/20 10:14 AM You've seen my paint job right? Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,045 Member For: 9y 1m 28d Gender: Male Location: South Australia Posted 22/12/20 10:18 AM Share Posted 22/12/20 10:18 AM @Admin (as if) you're slacking mate Link to comment Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,403 Member For: 14y 3m 4d Gender: Male Location: Melbourne Posted 22/12/20 10:21 AM Share Posted 22/12/20 10:21 AM you rang? Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 9m 27d Gender: Male Location: Adelaide Posted 22/12/20 10:24 AM Share Posted 22/12/20 10:24 AM You don’t notice the spammer ya clammer @Admin (as if) Link to comment Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,403 Member For: 14y 3m 4d Gender: Male Location: Melbourne Posted 22/12/20 10:25 AM Share Posted 22/12/20 10:25 AM yer nah I didnt scroll up commented in his thread though ban time 1 Link to comment Share on other sites More sharing options...
violetpop Silver Donating Members 436 Member For: 4y 3m 21d Posted 24/12/20 06:57 AM Author Share Posted 24/12/20 06:57 AM Engine came out of the car at last! Bit cruddy in the hard to reach spots on the k frame and some areas but plan to get in all the little nooks in the engine bay and give them a good tidy up and maybe even a lick of taxi white paintI was able to make a start on the gas engine and will focus on that first.Valve springs, oil gears and swap over my turbo specific stuff - sump, oil feed fitting, hard water pipes. The full rocker cover gasket kit and timing case kits are ready to pick up too so the last gasket will be the sump which I will confirm when I remove the it from the turbo.I'd like to tinker around with the wiring snaking its way around the manifold and possibly route it in a way that all I need to do is remove the fuel rail and be able to pull the manifold out as one whole part quickly and easily. Specifically the wiring that runs through the rear runner which is for the rear coils and trans from memory. 2 Link to comment Share on other sites More sharing options...
