Roley94 Member 114 Member For: 11y 19d Gender: Male Location: Perth Posted 18/12/19 09:18 AM Share Posted 18/12/19 09:18 AM I can’t find the thread discussing the different lengths between the b series and fg Ute diffs and I cant remember what’s what, I’ve just pulled the axles out of my ba turbo Ute and put them next to what I know are bf xr8 axles and the ones I pulled out are about 25mm longer. I’m quite sure turbo and xr8 diffs are the same. The Ute has also had a zf conversion so I wouldn’t be surprised if the whole diff was swapped out. Would that mean I have an fg diff in my ba? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,238 Member For: 15y 11m 18d Gender: Male Location: Melbourne Posted 18/12/19 09:27 AM Share Posted 18/12/19 09:27 AM if your BA ute has been converted to ZF, it's either a BF setup or a FG setup, but either way it'll be a 2.73 LSD diff (if it was the full driveline kit from whatever car the ZF came from) and it does have different axles and lengths. Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 10y 1m 16d Gender: Male Location: SW Sydney Posted 18/12/19 09:54 AM Share Posted 18/12/19 09:54 AM @OZYWALKER can confirm but pretty sure FG diff disc to disc is 40-50mm longer which would agree with what you're suggesting 1 Link to comment Share on other sites More sharing options...
Roley94 Member 114 Member For: 11y 19d Gender: Male Location: Perth Posted 18/12/19 10:16 AM Author Share Posted 18/12/19 10:16 AM Yes it is 2.73 ratio but the label on the diff is gone so I can’t tell if only the gears had been swapped into the original diff or if the whole diff was swapped. If the fg diff is 50mm then that confirms it. Link to comment Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 10y 10m 27d Gender: Male Location: Western Sydney Posted 18/12/19 11:26 AM Share Posted 18/12/19 11:26 AM I can measure it on Sat to be exact if you like but I can 100% say that the FG axle is 50mm wider than the BA/BF axle for the utes. Link to comment Share on other sites More sharing options...
Roley94 Member 114 Member For: 11y 19d Gender: Male Location: Perth Posted 18/12/19 12:19 PM Author Share Posted 18/12/19 12:19 PM Don’t worry about measuring it, I’d say it’s definitely a fg diff then. Thanks guys 1 Link to comment Share on other sites More sharing options...
BeerTurbo Donating Members 231 Member For: 5y 10m 19d Posted 17/05/22 01:47 PM Share Posted 17/05/22 01:47 PM I smashed an axel in my b series ute. So now im having fun finding a replacement. I have what I thought was just a 373 ba turbo manual diff. My spare diff from a xr8 ba lsd has different length axels. I just had a guy measure his on marketplace. Bf turbo auto, axels measured same as my spare. From the metal collar before bearing, they are 73 cm and 67cm. One im trying to find is 70cm for that same measurement. Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 8m 7d Posted 18/05/22 02:51 AM Share Posted 18/05/22 02:51 AM Quality search and info find. Well done. To answer your question. Your farked Sounds like your doing a diff swap or alot of ringing and measuring. There appears to be a shop selling them on ebay. They can probably give you a measurement. Link to comment Share on other sites More sharing options...
BeerTurbo Donating Members 231 Member For: 5y 10m 19d Posted 18/05/22 02:59 AM Share Posted 18/05/22 02:59 AM I measured both my diffs and they are the same. 1500 Both LSD Different length axels. Yeah I called some local driveline places n they said ford genuine. The ebay shop said they have the one I need yes. I was hoping to buy sh axels cheap. But looks like ill be buying new. Just kinda annoying there different lengths. Be nice to have spares Link to comment Share on other sites More sharing options...
