DavidF Member 31 Member For: 4y 4m 13d Posted 21/12/19 10:31 PM Author Share Posted 21/12/19 10:31 PM On 07/12/2019 at 8:57 PM, k31th said: if you want to bypass the boost control solenoid, you just take the pipe that goes from the nipple at the front of the turbocharger and then connect it to the nipple on the wastegate actuator. I removed the pipe from the nipple at the front of the turbo charger and connected it to the westgate actuator. Is this correct? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 9d Gender: Male Location: Melbourne Posted 21/12/19 11:44 PM Share Posted 21/12/19 11:44 PM a single pipe should connect the nipple on the turbocharger to the nipple on the wastegate actuator, so if you've done this then yes, that's the way to get it to minimum boost at the slowest ramp rate. Link to comment Share on other sites More sharing options...
DavidF Member 31 Member For: 4y 4m 13d Posted 22/12/19 12:18 AM Author Share Posted 22/12/19 12:18 AM I find it odd that the car preforms worse now. that's why I questioned if I done it correctly. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 9d Gender: Male Location: Melbourne Posted 22/12/19 01:15 AM Share Posted 22/12/19 01:15 AM the tune may not like this situation... but if you mean "perform worse" by it's slower and doesn't feel as fast then of course that'll happen when you go back to minimum boost with the slowest ramp rate. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 23d Gender: Male Location: Perth Posted 22/12/19 03:33 AM Share Posted 22/12/19 03:33 AM 5 hours ago, DavidF said: I removed the pipe from the nipple at the front of the turbo charger and connected it to the westgate actuator. Is this correct? No. See Keiths post. "A single pipe should connect the nipple on the turbocharger to the nipple on the wastegate actuator" Link to comment Share on other sites More sharing options...
DavidF Member 31 Member For: 4y 4m 13d Posted 22/12/19 05:48 AM Author Share Posted 22/12/19 05:48 AM (edited) Completed this and the car did not fault. But I have also noticed that the car did not fault when the A/C was on. Switch the A/C off and the car faulted. Also noticed that then the car was being driven at a constant cruising speed that it sounded like the turbo was kicking in and the car going faster then cut out and cut back in again. This has only happened once. Not sure if these are related or other problems. Edited 22/12/19 05:53 AM by DavidF Link to comment Share on other sites More sharing options...
DavidF Member 31 Member For: 4y 4m 13d Posted 22/12/19 02:04 PM Author Share Posted 22/12/19 02:04 PM 7 hours ago, DavidF said: Wanted to edit my last post as it was not clear. Unable to do so. Too sum up.... Purchased a 2007 territory and do not know who the tuner is or what exactly has been done to the car. Under heavy acceleration in 1st gear and just before the 2nd gear change the car would splatter and lose power and it felt like it had run out of fuel. This splatter and loss of power did not take place while the A/C was on. While driving at a constant speed I noticed that the car would slightly go faster and then pull back. This going faster and pulling back happened a few times within 30 sec and this problem has only happened once. As advised by k31th I bypassed the boost control solenoid and this stopped the car from splattering and losing power between 1st and 2nd gear change. Thanks for your input and help. What would you suggest my next step me? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 9d Gender: Male Location: Melbourne Posted 22/12/19 02:39 PM Share Posted 22/12/19 02:39 PM take it to a dyno tuner; have a look in the state-forum "recommended" places and ring around to the places that sound interesting enough, get a feel for who you'd like to take it to based on quotes etc and get it actually tuned or run-up and put to completely stock setup. or just get it run up on a dyno to anybody nearby with a dyno and see if it's running correctly in terms of the tune. Link to comment Share on other sites More sharing options...
DavidF Member 31 Member For: 4y 4m 13d Posted 12/07/20 03:16 AM Author Share Posted 12/07/20 03:16 AM Just removed the turbo and the actuator is moving freely. I am unsure how to test the actuator for faults. All the exhaust bolts and the manifold bolts to the turbo housing were all loose but was not able to hear exhaust leaks under the hood. Not sure if this has a effect over boosting. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 9d Gender: Male Location: Melbourne Posted 12/07/20 03:21 AM Share Posted 12/07/20 03:21 AM unlikely to overboost with leaking exhaust you test the actuator by applying pressure to it on the rated level and the actuator should move to fully open at it's rated pressure. Link to comment Share on other sites More sharing options...
