Ecu issues
Danny_
  • Member For: 4y 5m 12d
Hi guys,
just having recently fixed my issue of the car having issues to idling I now am having issues wuth the second issue.
Car is a 6cyl ba Fairmont ghia with a 4 speed auto.
Ever so often it would go into limp mode and the gearbox would throw codes,
Changed oil and filter and that did. It resolve the issues.
A search online shows it could be the ecu and I replaced that and this is where more issues start.
I went from a 32AE to a 32AD ecu and had it programmed.
Took the car for a drive and the second it changes gear throws it into limp mode (speedo doesn't work either)
He tried to reprogram it and tried again, same code p0500.
Could I have been sold an ecu for a Ute and not a sedan?
It keeps looking for a speed sensor that the Ute's have and sedans don't have,
The guy that programmed it wasn't sure if Ute ecus will work in sedans.
Thanks.
Daniel.
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 15d
well, you definitely need to either get somebody who knows how to re-program the strategy on the PCM (it's Ford's name for the ECU) to suit a Sedan versus a Ute variant, but if you're sticking with the same guy, then get the same model variant of the PCM (it should be fairly cheap considering you're after an N/A one instead of a turbo one) at a wreckers and get that coded for your car.
Sorry for all the spelling mistakes and the poor formatting. It wouldn't let me edit it and I was taking the train to work 😕
The guy that programmed it came recommended by the person I bought the ecu off (Ford pro wreckers) and the programming set me back $200
I am not sure if many people can program the ecus.
I am used to driving 40+ years old cars with no bloody ecus.
  • Site Developer
your spelling was fine :idunno:
well, go back to the same guy with a correct PCM and get it re-done correctly by him, under "warranty for work" or whatever you might be able to get through him, as he clearly didn't get it working to a satisfactory level.
