Danny_ New Member 9 Member For: 4y 5m 6d Posted 30/11/19 05:50 PM Share Posted 30/11/19 05:50 PM Hi guys, just having recently fixed my issue of the car having issues to idling I now am having issues wuth the second issue. Car is a 6cyl ba Fairmont ghia with a 4 speed auto. Ever so often it would go into limp mode and the gearbox would throw codes, Changed oil and filter and that did. It resolve the issues. A search online shows it could be the ecu and I replaced that and this is where more issues start. I went from a 32AE to a 32AD ecu and had it programmed. Took the car for a drive and the second it changes gear throws it into limp mode (speedo doesn't work either) He tried to reprogram it and tried again, same code p0500. Could I have been sold an ecu for a Ute and not a sedan? It keeps looking for a speed sensor that the Ute's have and sedans don't have, The guy that programmed it wasn't sure if Ute ecus will work in sedans. Thanks. Daniel. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,291 Member For: 16y 9d Gender: Male Location: Melbourne Posted 30/11/19 10:55 PM Share Posted 30/11/19 10:55 PM well, you definitely need to either get somebody who knows how to re-program the strategy on the PCM (it's Ford's name for the ECU) to suit a Sedan versus a Ute variant, but if you're sticking with the same guy, then get the same model variant of the PCM (it should be fairly cheap considering you're after an N/A one instead of a turbo one) at a wreckers and get that coded for your car. Link to comment Share on other sites More sharing options...
Danny_ New Member 9 Member For: 4y 5m 6d Posted 30/11/19 11:11 PM Author Share Posted 30/11/19 11:11 PM Sorry for all the spelling mistakes and the poor formatting. It wouldn't let me edit it and I was taking the train to work 😕 The guy that programmed it came recommended by the person I bought the ecu off (Ford pro wreckers) and the programming set me back $200 I am not sure if many people can program the ecus. I am used to driving 40+ years old cars with no bloody ecus. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,291 Member For: 16y 9d Gender: Male Location: Melbourne Posted 30/11/19 11:47 PM Share Posted 30/11/19 11:47 PM your spelling was fine well, go back to the same guy with a correct PCM and get it re-done correctly by him, under "warranty for work" or whatever you might be able to get through him, as he clearly didn't get it working to a satisfactory level. Link to comment Share on other sites More sharing options...
