ilk Is on holiday from communism Member 1,282 Member For: 5y 2m 26d Gender: Female Location: Victoria Posted 29/11/19 12:58 AM Share Posted 29/11/19 12:58 AM Had a strange problem that my FG xr6 turbo would have a misfire when the car warmed up or sat for a while after driving around. And it was very intermittent, nothing in particular would cause the same problem. Checked plugs, ignition coils, wiring, battery, earth cables, connections to coils and injectors all seemed fine. I thought it might have been the coil drivers in the PCM so was ready to set the car on fire.. Long story short, clean your connections first. I took every connection off the injectors and ignition coils and sprayed them with CRC. Problem fixed. Drives like new again. Hope this helps someone before they lose their minds 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,239 Member For: 15y 11m 19d Gender: Male Location: Melbourne Posted 29/11/19 12:59 AM Share Posted 29/11/19 12:59 AM good job, ya filthy animal 1 Link to comment Share on other sites More sharing options...
