Sammy197 New Member 1 Member For: 4y 5m 5d Posted 18/11/19 11:28 AM Share Posted 18/11/19 11:28 AM Hey guys. I've got a f6x territory and are planning on getting a few more hps out of it. I've got the cold air intake, 4" stainless exhaust, front mount intercooler, 1000cc injectors, 470l p/h pump, upgraded valve springs and performance cams. My question is am I going to new a new ecu to run this setup or will the factory one be tunable to do the job. Thanks in advance. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,302 Member For: 16y 14d Gender: Male Location: Melbourne Posted 18/11/19 11:36 AM Share Posted 18/11/19 11:36 AM the factory one is fine for almost all applications it's quite rare to need to upgrade it. 1 1 Link to comment Share on other sites More sharing options...
BeerTurbo Donating Members 234 Member For: 5y 11m 15d Posted 19/11/19 12:28 PM Share Posted 19/11/19 12:28 PM Stock ECU is fine. In my territory I have pretty standard "mods" and along the line your going : Walbro Fpump, just make sure you put in direct power for the fuel pump the use alot of power. Front mount FG exhaust manifold, 45mm turbosmart wastegate, stock gt3582, 4inch dump, 3.5inch exhaust. using stock PCM's boost controller. Fg intake manifold Xspurt 1000cc injectors this is all controlled by stock PCM, using PCMTec to modify the PCM parameters. The stock PCM is quite powerful and verry configurable. I also have a pretty much identical setup in a ba ute, same thing - stock ecu is fine. 1 Link to comment Share on other sites More sharing options...
Draino Donating Members 68 Member For: 4y 7m 29d Gender: Male Location: NT Posted 01/12/19 08:50 AM Share Posted 01/12/19 08:50 AM (edited) On 19/11/2019 at 9:58 PM, BeerTurbo said: FG exhaust manifold Does this set the turbo location back towards the firewall a bit? How much do you think/did you measure if so? Edited 01/12/19 08:51 AM by Draino Link to comment Share on other sites More sharing options...
BeerTurbo Donating Members 234 Member For: 5y 11m 15d Posted 01/12/19 10:42 AM Share Posted 01/12/19 10:42 AM from memory the difference is about one cm. Link to comment Share on other sites More sharing options...
