Eather40 New Member 19 Member For: 5y 1m 4d Posted 11/10/19 05:02 AM Share Posted 11/10/19 05:02 AM What kind of power figures are people making and running safely on Unleaded 98 before moving to E85 Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 21d Gender: Male Location: Perth Posted 11/10/19 05:15 AM Share Posted 11/10/19 05:15 AM I made 250rwkw. Filled up with E85 and made 255rwkw. Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 17d Gender: Male Location: Adelaide Posted 11/10/19 08:40 AM Share Posted 11/10/19 08:40 AM I think op wants to know what a typical gain is on E85 conversions the answer is twice as long as it’s half .... more information please OP a Maxed out FG turbo will go from 330rwkw to 350rwkw a maxed out BA/BF will go 380rwkw to 440rwkw a maxed out full build with big turbo could go 400rwkw to 500rwkw its a hardware dependent answer Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 21d Gender: Male Location: Perth Posted 11/10/19 08:45 AM Share Posted 11/10/19 08:45 AM Oh. I thought he was asking about my E85 commodore. I went from 407 on 98 to 480 on E85. Just injectors , pump, regulator and tune. Factory turbo But typical say 60 rwkw on ford big turbo. 1 Link to comment Share on other sites More sharing options...
Eather40 New Member 19 Member For: 5y 1m 4d Posted 11/10/19 10:00 PM Author Share Posted 11/10/19 10:00 PM Sorry guys that was a pretty vauge question. I've been told that for a modified fg you wouldn't want to make much more than 400rwkw on 98 otherwise you can start causing damage to the engine. I'm wondering if this is true and in what way e85 would be better and if it's not true what kind of power and reliability are people seeing from a 98 fed car Link to comment Share on other sites More sharing options...
Eather40 New Member 19 Member For: 5y 1m 4d Posted 11/10/19 10:59 PM Author Share Posted 11/10/19 10:59 PM All on unopened block with headstuds and valve springs. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,281 Member For: 16y 7d Gender: Male Location: Melbourne Posted 12/10/19 12:23 AM Share Posted 12/10/19 12:23 AM 2 hours ago, Eather40 said: Sorry guys that was a pretty vauge question. I've been told that for a modified fg you wouldn't want to make much more than 400rwkw on 98 otherwise you can start causing damage to the engine. I'm wondering if this is true and in what way e85 would be better and if it's not true what kind of power and reliability are people seeing from a 98 fed car that's basically true for an FG F6 turbocharger (or a BA/BF one), as it maxes out around 400rwkw... of course 98 puts more stress on an engine as it needs to run higher boost than E85 for equivalent power, but realistically, once you're up over 400rwkw, any fuel is going to cause premature wear to an engine... E85 is just better for cylinder pressures overall as you can run timing changes instead of just heaps of boost. If you run a good quality tune and you maintain the car, a 98 tune is perfectly fine to run with as much power as you're willing to make with an upgraded turbo E85 will just make the same power easier but at the cost of fuel economy and fuel station convenience. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 21d Gender: Male Location: Perth Posted 12/10/19 01:20 AM Share Posted 12/10/19 01:20 AM (edited) Timing and boost, which is governed by fuel. The more of each the more power. Ford big turbo can be pushed past 400 on 98. But if you want more may as well go E85. BUT it you want to stay with 98 just get a bigger turbo. Here is 400rwkw on 98 at 15psi, factory BF F6 turbo. We could push this past 20psi on this engine, reduce timing, but lower boost is better. You probably want to stay at about 18psi for unopened engine. Edited 12/10/19 01:22 AM by arronm Link to comment Share on other sites More sharing options...
kyle173 Donating Members 774 Member For: 15y 5m 16d Gender: Male Location: brisbane Posted 12/10/19 01:22 AM Share Posted 12/10/19 01:22 AM all bolt ons stock turbo 98 was 388rwkw E85 went to 420RWKW stock oil pump no head studs. CV, Diff and transmission will be the first things that die. Link to comment Share on other sites More sharing options...
