Dump pipe
Slowxr6t
  • Member For: 5y 3m 24d
So I'm making my own dump pipe, I was intending on making it out of 4inch steam pipe bends for durability, it will fit but it's a tight squeeze, now I think I will make it out of 3.5 inch steam pipe, it will be lighter and have much better clearances and pretty sure won't restrict power up to 400rwkw, I'm going to run a 45mm turbosmart external wg and plumb it back in right down the bottom where the exhaust runs flat under car.
So I ended up making dump pipe out of 4 inch black steam pipe bends, 1 long radius 90 bend and 1 short radius 90 bend. I used the stock dump bracing brackets, I welded some bits of 10mm thick flat steel to the dump pipe to mate up to the brackets. It's all worked out real good. I couldn't  get 3.5 inch steam pipe bends so thanks @FiftyOne now il have maximum street cred lol.
And it looks seriously bulletproof, she won't be cracking anytime soon.
  • 2 months later...
