k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 01/11/19 07:44 AM Share Posted 01/11/19 07:44 AM well, try the engine block. Link to comment Share on other sites More sharing options...
Hornblower Member 50 Member For: 21y 2m 26d Location: Spit Junction NSW Posted 01/11/19 08:11 AM Author Share Posted 01/11/19 08:11 AM OK, just tried that too. One big click on the first try, then the engine fires OK on the second turn. Link to comment Share on other sites More sharing options...
Rab WOT? Moderating Team 10,980 Member For: 11y 1m 30d Gender: Male Location: Frankston, 3199 Posted 01/11/19 08:38 AM Share Posted 01/11/19 08:38 AM I get the click the 1st time I try to start after a flash Link to comment Share on other sites More sharing options...
Hornblower Member 50 Member For: 21y 2m 26d Location: Spit Junction NSW Posted 01/11/19 08:42 AM Author Share Posted 01/11/19 08:42 AM hmmm, so maybe it is related to the ECU, though that was overhauled by Injectronics around 12 months ago. The car's never been flashed though. Link to comment Share on other sites More sharing options...
Rab WOT? Moderating Team 10,980 Member For: 11y 1m 30d Gender: Male Location: Frankston, 3199 Posted 01/11/19 08:51 AM Share Posted 01/11/19 08:51 AM Could be a solenoid somewhere? Link to comment Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 10y 29d Posted 01/11/19 06:00 PM Share Posted 01/11/19 06:00 PM Put a volt meter on the battery as some one else try's to start it, should be around 10v if it's under this replace battery, if it stays around 12-13v change starter. because you get a 'clack' from the starter the ignition switch, inhibitor, ecu & relay are working. You earthed the jump pack to the block so I assume that the earth is OK . Starters are cheap but they're not easy to change. I recon the FG ones turn the engine over faster & will fit after you cut the extra tag off Link to comment Share on other sites More sharing options...
Hornblower Member 50 Member For: 21y 2m 26d Location: Spit Junction NSW Posted 01/11/19 08:32 PM Author Share Posted 01/11/19 08:32 PM Thanks for the tip 4321, I'll give it a go when I'm next back to the car. I'm back at the farm now packing my bags for 10 days in the Hawaiian Islands, so will get back into the detective work when I return in a few weeks... Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 29d Gender: Male Location: Perth Posted 02/11/19 02:06 AM Share Posted 02/11/19 02:06 AM (edited) I havnt read the whole thread but have you cleaned the battery terminals. ?? Also check the cable connection at the starter motor Edited 02/11/19 02:07 AM by arronm Link to comment Share on other sites More sharing options...
Hornblower Member 50 Member For: 21y 2m 26d Location: Spit Junction NSW Posted 02/11/19 03:25 AM Author Share Posted 02/11/19 03:25 AM No, good tip to clean the battery terminals though, and I'll check the connection to the starter when I get back to the car in a few weeks, Thanks for that Link to comment Share on other sites More sharing options...
