MCNLT New Member 6 Member For: 4y 11m 8d Gender: Male Posted 17/09/19 12:22 PM Share Posted 17/09/19 12:22 PM (edited) So I've tried searching this no avail to get the answer I'm after I've got a 2005 ba xr6t. Looking to build the motor but I was planning on buying a block and possibly head and building it then pulling my motor out and putting this one in My question is Can I just buy say a FG xr6t NA motor or egas motor Use the block and possibly the crank if it's same from turbo to NA? Unsure of the crank and put new rods, pistons, oil pump, etc Then swap the sump to a turbo sump for the oil return line and put a turbo head on? Thanks in advance Edited 17/09/19 12:23 PM by MCNLT Forgot to clarify crankshaft Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,239 Member For: 15y 11m 19d Gender: Male Location: Melbourne Posted 17/09/19 12:47 PM Share Posted 17/09/19 12:47 PM Yes, you can use an N/A engine block/crank then build from there with rods/pistons and oil pump etc depending on your power goals. You don't strictly need a turbo sump as you can just drill a hole and tap some bolt threads for the turbo oil return. The only thing different in the head is the valve springs and exhaust valves, so you can upgrade the valve springs anyway and just get some exhaust valves for the head. 1 Link to comment Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 10y 2d Posted 17/09/19 07:02 PM Share Posted 17/09/19 07:02 PM And you might have to drill the dipstick hole (depending on how later the fg block is ie early fg blocks were supposedly drilled for both with frount hole capped off) fg heads are supposedly better than earlier ones 2 Link to comment Share on other sites More sharing options...
HI PSI Member 1,563 Member For: 17y 10m 4d Gender: Male Location: Central Queensland Posted 18/09/19 12:55 PM Share Posted 18/09/19 12:55 PM My spare engine has both dipstick holes. The FG location has a bung in it.. Link to comment Share on other sites More sharing options...
