Off stock manifold or turbine housing for external wastegate location
Slowxr6t
  • Dropping a turd
  • Member For: 16y 5m 2d
3 hours ago, Slowxr6t said:
What's wrong with stock engine mounts? What aftermarket ones are best?
Nothing.  Just hard to change . Best done with turbo off
  • Member For: 5y 10m 20d
7 hours ago, Slowxr6t said:
@BeerTurbo I like the j pipe, but intake, outlet, oil and water lines would all need modifying in my case.
allready had a braided oil feed - that works fine with highmount to.
cut the oil return pipe in the solid part and conected oilproof hose to it to extend the length.
overflow side water line works fine with a bit more hose, it has a small join std, just needs a bit more highmount.
I did bend the engine side water line to work, but it was a right *beep*. ended up replacing it with a different fitting and hose.
