Ben Evans New Member 8 Member For: 5y 12d Posted 05/09/19 11:45 PM Share Posted 05/09/19 11:45 PM Hey all I was planning on putting a dose pipe on my Bf xr6t, I relocated my battery behind my bumper and didn’t realise that the cold side piping would still be in the way of fitting my dose pipe. What is the cheapest option to move the piping to give me the room. Cheers Link to comment Share on other sites More sharing options...
MBAF Bronze Donating Members 2,156 Member For: 7y 8m 9d Posted 06/09/19 04:25 AM Share Posted 06/09/19 04:25 AM Pics? How is it exactly in the way? Bf pipe work drops down below the motor so there should be no clearance issues from the intake Link to comment Share on other sites More sharing options...
Ben Evans New Member 8 Member For: 5y 12d Posted 08/09/19 10:56 PM Author Share Posted 08/09/19 10:56 PM Hey mate sorry for the late reply, here is a photo mind the dirty engine bay and tape job Link to comment Share on other sites More sharing options...
Ben Evans New Member 8 Member For: 5y 12d Posted 09/09/19 03:55 AM Author Share Posted 09/09/19 03:55 AM (edited) On 06/09/2019 at 2:25 PM, MBAF said: Pics? How is it exactly in the way? Bf pipe work drops down below the motor so there should be no clearance issues from the intake It’s directly in front of the turbo blocking access for a dose pipe where the battery would usually sit. I posted a photo above Edited 09/09/19 03:56 AM by Ben Evans More info Link to comment Share on other sites More sharing options...
Ben Evans New Member 8 Member For: 5y 12d Posted 10/09/19 01:17 AM Author Share Posted 10/09/19 01:17 AM Bump Link to comment Share on other sites More sharing options...
HI PSI Member 1,572 Member For: 17y 10m 30d Gender: Male Location: Central Queensland Posted 10/09/19 06:37 AM Share Posted 10/09/19 06:37 AM I'm a little confused. A dose pipe is a pipe that vents wastegate pressure. How are you planning on doing that with a standard turbo and housing assembly. Btw, you might want to upgrade your cooler and piping before doing anything else.. Those standard hoses are poo... That will help your cause, by making more room.. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,302 Member For: 16y 14d Gender: Male Location: Melbourne Posted 10/09/19 06:48 AM Share Posted 10/09/19 06:48 AM a "dose pipe" is a short pipe off the front of a turbo that accentuates the turbo noises but the rest of what you said is correct, though... need to upgrade the intercooler setup with regard to piping before you'll be able to fit a dose pipe in there. 1 Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,751 Member For: 12y 9m 3d Posted 10/09/19 06:48 AM Share Posted 10/09/19 06:48 AM I've never done it myself but can dodgy up some 90 degree 3" pipe. Option Also you can use the ribbed flex pipe that runs between the factory airbox and the cross over as it clamps straight to the turbo. Other then that your looking at intercooler kit and cold side piping like process west, plazmaman rapid etc Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,302 Member For: 16y 14d Gender: Male Location: Melbourne Posted 10/09/19 06:49 AM Share Posted 10/09/19 06:49 AM I would never recommend anybody do what's done in that video though... hot air intake FTL Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 28d Gender: Male Location: Perth Posted 10/09/19 07:19 AM Share Posted 10/09/19 07:19 AM (edited) 34 minutes ago, gaz097 said: I've never done it myself but can dodgy up some 90 degree 3" pipe. Option Also you can use the ribbed flex pipe that runs between the factory airbox and the cross over as it clamps straight to the turbo. Other then that your looking at intercooler kit and cold side piping like process west, plazmaman rapid etc Sounds like a school girl giggling. Gahy as... No its a chipmonk. Edited 10/09/19 07:24 AM by arronm Link to comment Share on other sites More sharing options...
