Puffwagon Puff Gold Donating Members 15,116 Member For: 9y 2m 20d Gender: Male Location: South Australia Posted 08/12/21 08:46 AM Share Posted 08/12/21 08:46 AM Should carry out much further when some boost duty is added to it. It'll be interesting to see what it looks like in a few weeks when it's turned up! Looks good mate, happy days Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 18d Gender: Male Location: Adelaide Posted 08/12/21 08:54 AM Share Posted 08/12/21 08:54 AM Looks like a really efficient set up there mate, graph is beautiful for the consumed boost ! Link to comment Share on other sites More sharing options...
Tom Tucker Donating Members 614 Member For: 4y 9m 19d Posted 08/12/21 09:06 AM Author Share Posted 08/12/21 09:06 AM Thanks lads. Looking forward to working through the next set of issues when I gets turned up haha. Loving the sound of it. 4" turbo back is brilliant, and I think the 4" vs 3.5" dump has helped bring it on slightly earlier than before. Hard to tell though, lots of changed made together Link to comment Share on other sites More sharing options...
Tom Tucker Donating Members 614 Member For: 4y 9m 19d Posted 11/12/21 05:33 AM Author Share Posted 11/12/21 05:33 AM You probably can't see in the photo, but I got the engine bay painted while the engine was out. Looks soooo much better. Got the IC-7 hooked up in a temporary location. I have an insert to place it into the dash cluster location, but the wiring for indicators and fuel sender will be a future project. Getting a few km on the drivetrain. Gearbox is loosening up slightly and shift quality improving. The Haltech self learning is improving idle target and drop between gears and fuel trim is getting better every time. Next job is to dump the run in oil (Penrite 15W-40 run-in). I'll run another 500km with a fresh lot of that same oil. It'll get some slightly thicker synthetic oil before it gets back on the dyno, which might quieten it up a little too. The 15W-40 seems to have lower oil pressure than I'd like. Sits at around 40psi cruising at 2000rpm, and gets up to 70psi in the upper rpm. I'd like to see an extra 20psi with a 15W-50 or 20W-60. I think the oil pressure is very similar to when I tried 10W-40 with the stock motor, and it ended up being spot on with 15W-50, so I'm not too concerned. I also have a PRP coil kit to go in. Working away on an FG rocker cover - shaving the bits I don't need, and I need to get some AN10 fittings welded on. 5 Link to comment Share on other sites More sharing options...
Tom Tucker Donating Members 614 Member For: 4y 9m 19d Posted 14/12/21 10:09 PM Author Share Posted 14/12/21 10:09 PM Run in seems to be going ok so far. Few little teething issues, as expected. The extra response is very noticeable. Third gear coming on boost blazes the rears now. Might not seem like much to auto owners who can get the wheels spinning in first or second and keep it going through the gears. Big difference to feeding it on in gear without a torque converter, and overwhelming 275 NT05 semi slicks 1 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,291 Member For: 16y 8d Gender: Male Location: Melbourne Posted 14/12/21 10:16 PM Share Posted 14/12/21 10:16 PM going to need vids of the outside as you blaze 3rd coming on Link to comment Share on other sites More sharing options...
Tom Tucker Donating Members 614 Member For: 4y 9m 19d Posted 14/12/21 11:15 PM Author Share Posted 14/12/21 11:15 PM I'll see what I can do 😉 But this is a good example of low down response making one of these cars feel fast, even though its only at 450kw Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,116 Member For: 9y 2m 20d Gender: Male Location: South Australia Posted 14/12/21 11:20 PM Share Posted 14/12/21 11:20 PM Mate don't get desensitized to forum dyno numbers, 450kw is fast as fark....still it's gonna be a different animal when it gets another 100 to 200kw added to it 1 Link to comment Share on other sites More sharing options...
Tom Tucker Donating Members 614 Member For: 4y 9m 19d Posted 15/12/21 06:39 AM Author Share Posted 15/12/21 06:39 AM You're right, it is fast. But it's a different kind of fast compared to a stock engine feeding the boost in slowly, and maybe hitting 500rwkw. This is a bit more of a handful on the street, which is what I wanted 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,116 Member For: 9y 2m 20d Gender: Male Location: South Australia Posted 15/12/21 07:59 AM Share Posted 15/12/21 07:59 AM Yerp have sent it in hard myself and really... that's the way it should be 1 Link to comment Share on other sites More sharing options...
