arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 23d Gender: Male Location: Perth Posted 22/09/19 10:54 AM Share Posted 22/09/19 10:54 AM Springs look fine, must be the diff bush..... Link to comment Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 10y 11m 18d Gender: Male Location: Western Sydney Posted 22/09/19 10:57 AM Share Posted 22/09/19 10:57 AM Thanks mate Do you have a pic of this setup?Nope. Looked the same as that non xr pic less the spacer plate. 1 Link to comment Share on other sites More sharing options...
Lithfkn Member 54 Member For: 4y 8m 30d Posted 02/10/19 10:09 PM Author Share Posted 02/10/19 10:09 PM I bit the bullet and threw in some solid steel saddle bushes and it hasn't made a difference to the sounds. I did notice that between each leaf through the middle there are steel plates, maybe 1mm thick. That's what's causing the illusion that there is gaps in the leafs. Is it normal that they have these thin plates through the middle? My mates leafs are completely sandwiched together. Also noticed when jacking the rear up the wheel has some back and forth movement, a couple mm. But not in and out. Is this just the slack in the diff/gears? Also got a centre bearing as that has collapsed from the top. Link to comment Share on other sites More sharing options...
Evster New Member 2 Member For: 4y 6m 12d Posted 07/10/19 02:41 AM Share Posted 07/10/19 02:41 AM To the OP I had similar symptoms in my FGII xr6t Ute with 90k on it, though mine is an auto. Ended up requiring a new LSD and center diff bearings, which completely eradicated the noises. The car is extremely quiet to drive now. Link to comment Share on other sites More sharing options...
Lithfkn Member 54 Member For: 4y 8m 30d Posted 07/10/19 02:44 AM Author Share Posted 07/10/19 02:44 AM Thanks Was it the clutches/plates in the diff that were buggered? Link to comment Share on other sites More sharing options...
Evster New Member 2 Member For: 4y 6m 12d Posted 07/10/19 03:37 AM Share Posted 07/10/19 03:37 AM He mentioned something about the plates but it was back at the start of the year so I don’t recall exactly. Sorry mate. Link to comment Share on other sites More sharing options...
Lithfkn Member 54 Member For: 4y 8m 30d Posted 07/10/19 04:27 AM Author Share Posted 07/10/19 04:27 AM Thanks mate. If you happen to remember or find out could you hit me up? I'm reading a lot about clutch plates knocking. Link to comment Share on other sites More sharing options...
JasonHyde New Member 1 Member For: 4y 5m 19d Posted 31/10/19 08:11 AM Share Posted 31/10/19 08:11 AM (edited) I have a FG MKII NA Ute doing the same sort of sounds. Multiple clunks on acceleration and a single clunk -sometimes- on decel. Doesn't happen when car is cold, and happens a lot if I'm in traffic moving at 20-40kph. have 68k on the clock and have had the sound for a fair while now. Finally took it to a mechanic the other week to which they checked over the whole thing and didn't find an issue other than "it's your leaf springs". He didn't really have an idea as to why they were causing a sound in particular. When listening it definitely does seem like it's coming from the springs on drivers side, but at the same time the clunk on takeoff isn't just a single clunk, it will go sort of CLUNK-clunkclunkclunkclunk sometimes. Also noticed sometimes when pulling up to a light slowly, the closer I get to stopping I get a clunk..clunk...clunk.....clunk. It's really weird and hard to replicate. Also you can hear a thunk in the rear when going over a speed bump or a decent bump in the road, almost like something is bouncing in the tray. Haven't tried much yet apart from getting the diff oil changed, which did nothing. If anything the noise got slightly a bit worse in traffic. Maybe I'm thinking them having the springs fully unloaded on the lift made it worse somehow? I have no idea. I'm pretty useless with cars if I'm honest but I'm learning a hell of a lot in the process of trying to find the cause and solution to this. Going to check everything is tight underneath, despite the mechanics saying everything is tight and nothing is worn. Might try to put something between the springs or something. Bleh. Edited 31/10/19 08:11 AM by JasonHyde 1 Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 10y 2m 7d Gender: Male Location: SW Sydney Posted 01/11/19 03:22 AM Share Posted 01/11/19 03:22 AM 19 hours ago, JasonHyde said: Also you can hear a thunk in the rear when going over a speed bump or a decent bump in the road, almost like something is bouncing in the tray. Check spare wheel is tight underneath for this noise Link to comment Share on other sites More sharing options...
Lithfkn Member 54 Member For: 4y 8m 30d Posted 23/11/19 02:17 AM Author Share Posted 23/11/19 02:17 AM On 31/10/2019 at 7:11 PM, JasonHyde said: I have a FG MKII NA Ute doing the same sort of sounds. Multiple clunks on acceleration and a single clunk -sometimes- on decel. Doesn't happen when car is cold, and happens a lot if I'm in traffic moving at 20-40kph. have 68k on the clock and have had the sound for a fair while now. Finally took it to a mechanic the other week to which they checked over the whole thing and didn't find an issue other than "it's your leaf springs". He didn't really have an idea as to why they were causing a sound in particular. When listening it definitely does seem like it's coming from the springs on drivers side, but at the same time the clunk on takeoff isn't just a single clunk, it will go sort of CLUNK-clunkclunkclunkclunk sometimes. Also noticed sometimes when pulling up to a light slowly, the closer I get to stopping I get a clunk..clunk...clunk.....clunk. It's really weird and hard to replicate. Also you can hear a thunk in the rear when going over a speed bump or a decent bump in the road, almost like something is bouncing in the tray. Haven't tried much yet apart from getting the diff oil changed, which did nothing. If anything the noise got slightly a bit worse in traffic. Maybe I'm thinking them having the springs fully unloaded on the lift made it worse somehow? I have no idea. I'm pretty useless with cars if I'm honest but I'm learning a hell of a lot in the process of trying to find the cause and solution to this. Going to check everything is tight underneath, despite the mechanics saying everything is tight and nothing is worn. Might try to put something between the springs or something. Bleh. Does yours have an LSD? Mine is definitely most noticeable from the passenger side wheel area but will sometimes get the double clunk. I got the centre bearing done and that eliminated some things but the rear clunk is still there. Link to comment Share on other sites More sharing options...
