Zlat347 Member 56 Member For: 6y 3d Posted 13/08/19 11:08 PM Share Posted 13/08/19 11:08 PM Hi all, wanted to see if anyone is having boost creep issues with this particular external gate? Or peoples experience using this exact gate on a barra. Not sure if its possiboy too small for the 4ltr barra? Running a 3584RS 1.21 rear. Trying to ramp in boost as it is too aggressive, so put a lower psi spring like a 7 or 10 and the boost will creep to 18-20psi pretty quickly. I run a haltech barra plug n play and am in open loop. Cheers Zac Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 24d Gender: Male Location: Adelaide Posted 13/08/19 11:30 PM Share Posted 13/08/19 11:30 PM (edited) The 50mm TS gates are a bit of a bugger sometimes for creep but with a RS84 and 1.21 it won’t be the gate, it’ll be the plumb back integration on the dump and or where the gate is being fed from The best location is off the manifold at the collector area, not the rear housing ! Disconnect the plumb back, let it scream for a single run and work out if it still creeps that turbo is going to come on late anyway and want to be in the early 20’s PSI wise ultimately for maximum efficiency Edited 13/08/19 11:33 PM by JETURBO Link to comment Share on other sites More sharing options...
Zlat347 Member 56 Member For: 6y 3d Posted 13/08/19 11:47 PM Author Share Posted 13/08/19 11:47 PM Its currently setup as screamer pipe so open. What I did just notice looking at it, on the top cap of wastegate there is 2 ports to vent to atmosphere, one port had a bung in it and otherside was open... I wonder if that was restricting the diaphram from opening fully? Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 24d Gender: Male Location: Adelaide Posted 14/08/19 12:02 AM Share Posted 14/08/19 12:02 AM Ok that’s one thing ticked off no that’s just to keep crap getting in there what Fuel are you on and what solenoid are you using ? Link to comment Share on other sites More sharing options...
Zlat347 Member 56 Member For: 6y 3d Posted 14/08/19 12:06 AM Author Share Posted 14/08/19 12:06 AM Running e85 and using the haltech MAC 3 port solonoid Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 24d Gender: Male Location: Adelaide Posted 14/08/19 12:14 AM Share Posted 14/08/19 12:14 AM Are you sure you have it connected as such ? if so what numbers timing wise have you thrown at it in an attempt to cool EGT down a touch ? Being on E85 you can throw some bigger numbers to see if this helps and has a dramatic effect being the fact your rear housing is so big it’s all going to come on in a big rush towards the end anyway Link to comment Share on other sites More sharing options...
Zlat347 Member 56 Member For: 6y 3d Posted 14/08/19 10:55 AM Author Share Posted 14/08/19 10:55 AM Ill have to have a look at timing, around the 14 mark from.memory at wot. My lines are exactly lile your picture As I was going through it I did also find the top braided line fitting loose that goes to the wastegate....not sure if air would have leaked or if this would impact it? Link to comment Share on other sites More sharing options...
Zlat347 Member 56 Member For: 6y 3d Posted 22/08/19 11:29 AM Author Share Posted 22/08/19 11:29 AM On 14/08/2019 at 10:14 AM, JETURBO said: Are you sure you have it connected as such ? if so what numbers timing wise have you thrown at it in an attempt to cool EGT down a touch ? Being on E85 you can throw some bigger numbers to see if this helps and has a dramatic effect being the fact your rear housing is so big it’s all going to come on in a big rush towards the end anyway Pulled the wastegate off, noticed a crack or missed weld on just before wastegate. Could this be causing wastegate boost creep? Second picture is with torch inside pipe showing hole Link to comment Share on other sites More sharing options...
Zlat347 Member 56 Member For: 6y 3d Posted 22/08/19 12:48 PM Author Share Posted 22/08/19 12:48 PM I also pulled the gate off and testes spring pressure with a compressor. 14psi spring Would crack open at 18.75 and fully open at 30psi 10psi spring Would crack open at 11psi amd fully open at 22.5 psi 7psi spring Would crack open at 7.5psi and fully open at 15psi Any body else done simular test? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,302 Member For: 16y 14d Gender: Male Location: Melbourne Posted 22/08/19 12:55 PM Share Posted 22/08/19 12:55 PM that's about right for an external gate... the 14psi spring is obviously a bit stronger than it's rating, but the others are close enough to within spec. 1 Link to comment Share on other sites More sharing options...
